Question about Dell S199WFP 19" Monitor
What size glare screen needed for dell S199WFP
Reflection off of screen
Plasma TV's are known for their glare and reflection issues, you can still fix it by buying a third party anti-glare filter and applying it on your television. For example, "ViewGuard" makes filters that goes up to 65" in size. It is not cheap though, depending on the size of your television.
Of course, the best solution is to adapt your room accordingly. If the glare is caused by the sun light coming from the windows, installing curtains on your windows or moving your television to a better spot is a very effective way to reduce the glare and the reflections on your television.
If the glare is caused by the room's lights, the best solution is to install ceiling spot lights with a dimmer.
Hope that helps!
Mar 19, 2014 | Samsung 51 Class Plasma 1080p 600Hz Smart...
Dell monitor S199WFP....the blue power light stays on....the screen goes black after a few seconds. I've checked the power cord and the cord connecting the monitor and computer. Do I just need to get a new...
What do you mean your screen goes black. It is black to start isn't it? Does it come on at all?
If you meam you are getting a display, but it goes off, you need to check the power settings for your monitor, that are set by your PC. Click start, then control panel, then double click display. Then in the Dispay Properties window, click the Screensaver tab at the top middle.In the lower half of the page which opens, you can find power settings, and the rest is self explanatory. If this is not the answer to your problem, you need to give more detailed information.
One check you can do is to disconnect the signal cable from your monitor, and switch power on, and see what is displayed. You may well need a new monitor, but before running off to buy one, try to borrow one to connect to your pc, and also if possible, try to connect your monitor to another pc, or to a notebook/laptop.
Jun 18, 2010 | Dell S199WFP 19" Monitor
Does this s199wfp monitor have audio
nope but you can get a soundbar for it for realtively cheap.
http://accessories.us.dell.com/sna/products/Video_Conferencing/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=313-6413
that soundbar is designed for the monitor it attaches perfect to the bottom.
Apr 06, 2010 | Dell S199WFP 19" Monitor
Why does everything on my screen look so small?
Hi:
One thing you can try is to right click your mouse, and go to properties, and lower your screen resolution settings. The higher the settings, the better quality picture, but icons and writing will get smaller and smaller. You just need to set it to something that is good for you! After you change it, you have about 30 seconds to accept your change, or it will go back the way it was.
Jan 23, 2010 | Dell S199WFP 19" Monitor
I am unable to restore to factory setting. how
http://support.dell.com/support/edocs/monitors/S199wfp/en/UG/setup.htm
The link provides how to operate all your Dell Display functions including the reset to factory defaults
Jun 23, 2009 | Dell S199WFP 19" Monitor
Glare is too much for my eyes, need a glare guard.
You can purchase a glare guard from 3m, available from cdw, tigerdirect, dell, 3m etc.
The price ranges from around $53 to $90 but you might find cheaper.
This is one model but there are several
3M™ EF200LB Anti-Glare/Radiation Computer Filter, Black Frame
May 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Screen glare on acer 5610-4610
I'm not sure what either of those suggestions would have to do with glare on the screen.
Could you try to describe, in detail, what this "glare" is that you are talking about?
Thanks!
Ron-
Nov 14, 2007 | Computers & Internet
Dell S199WFP 19" Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
