Question about VeriFone VX 610 Credit Card Terminal (CDMA) (25654336USD)
Turn off vx610 - VeriFone VX 610 Credit Card Terminal (CDMA) (25654336USD)
How to turn on the verifone vx610 terminal
Push the green button and hold it for about 5 or 10 seconds.
Make sure it is charged up first.
Optionally pull the battery out and connect the charger.
It should boot up automatically.
Jun 21, 2014 | VeriFone VX510
How do i power off a verifone vx610
unplug power or press small button on side if you have one
Jun 13, 2014 | VeriFone Omni 3700
How do I turn off a verifone vx610
  1. Disconnet the power cable.
  2. Hold the red cancel key for ten seconds.
  3. Remove the battery
May 14, 2014 | VeriFone VX510
How do you turn off the sleep mode on a vx610 cdma
go setting >> then sleep mode >> select close
Feb 06, 2014 | VeriFone Computers & Internet
What does TAMPER
"TAMPER" displays on Vx510, Vx610, or Vx670 terminal Problem/Task "TAMPER" shows on Vx510, Vx610, or Vx670 terminal Environment VeriFone Connect Any Verifone manufactured device that has the capability to contain it's own internal encryption (including Vx510, Vx610, or Vx670 terminal) Cause The message: "Tamper" will appear on the Vx510, Vx610, or Vx670 terminal if it is physically opened, damaged, or if it is jarred enough to flip and enable the internal tamper 'switch'. The reason for this is to ensure any sensitive data that passes through the terminal during a credit card transaction is not intercepted or compromised. Customer Solution/Action 1.
Contact repair facility for repair/replacement of the affected device
If you still needs help call us at (775)358-2922 ask for Randy http://freshpoint.org
Sep 29, 2012 | VeriFone Omni 3700
I need a download for an operations manual for a Verifone vx610
Hi, welcome to FixYa.
I hope this is the document you needed:
http://www.verifone.com/PDF/guides/23216_Omni_5xxx_vx5xx_vx6xx_Installation_Guide.pdf
Mar 17, 2011 | Computers & Internet
I need an download for an operation manual for a Verifone vx610
Hey there,
Here is a link to the manual you need: http://www.verifone.com/PDF/guides/23216_Omni_5xxx_vx5xx_vx6xx_Installation_Guide.pdf
Hope this helps! If it did, feel free to rate me. Thanks for using FixYa.
My Verifone Vx610 says "shutdown complete" on the screen. I cannot turn it on. What can I do?
remove power adapter then press alpha button or long press cancel key
Apr 18, 2010 | VeriFone VX510
Verifone vx610
#1 You need the Vmac and Comserv applications that were deleted when you cleared memory in order to perform an IP download. Without them you can only perform a dial only download.
#2 The programming for your VX510 will not load in your VX610 because they doth identify to the server as different models. If you did get the vx610 to connect and request your vx510 file you would only recieve an error "Application not configured" or "file not found"
Pro Tip: You can still clone VX terminals reguardless of model with the correct cable. Enter system mode and press 0 the # or 0 then * to send and recieve. This would put the application from the vx510 into the vx610 but your vx610 may not work through a com method other than dial depending on your processor.
Feb 10, 2010 | Computers & Internet
Verifone vx610 decline code 248
This is tricky to answer... different processing service use different codes. If the software you are running is built on a St. Pete's platform, this code means that the transaction you were processing was a 'reversal' (void) and the amount entered didn't match the original.
If you were running a sale and received this code and the display or receipt actually printed "declined" - it is a valid response indicating the customer card was declined and the code tells the service rep at your processing center why it was turned down (over limit, high risk, frozen account, etc...). If the response did show the word "declined", you can call your customer service department for your processor and they should be able to tell you what the code means in their system. If they don't - change processors as this is a standard service.
Aug 25, 2009 | VeriFone VX510
VeriFone VX 610 Credit Card Terminal (CDMA) (25654336USD) Logo
43 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
