Question about Halo 5 In. Boxed Recessed Light Fixture H5ICAT - 6 Pack
Halo h199ct ip recesssed light installation
How do i remove?
Replacing halo and hid lighting in an after market headlight
    Aftermarket Projector Headlight How To Replace HID ...
    store.ijdmtoy.com/Aftermarket-Projector-Headlight-HID-Installation.../5...
    Here are some quick tips and instructions on how to install an aftermarket HIDConversion kit into an aftermarket projector headlight assembly. ... Aftermarket projector headlights look almost like an OEM headlight with the exception of the wiring and design. You would need to remove ... images for Replacing halo and hid lighting in an ...
Nov 24, 2015 | 2000 Jeep Grand Cherokee
How do I replace front HID light bulb? and where can I purchase parts for replacing?
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
May 21, 2014 | BMW 335i Cars & Trucks
I have problem with hid light
follow this link to u-tube video not the exact vehicle but the principle will be the same,or search for your exact vehicle
How to replace low beam xenon HID bulbs 2006 BMW 330i
May 08, 2014 | 2007 BMW 335i Coupe
How to change headlight bulb
On the back of the headlight where the wires enter, you should be able to twist and remove the lamp holder. Be careful with the new bulb if it is halogen, do not touch the bulb!!
Apr 13, 2013 | 2000 Hyundai Sonata
Replace headlight bulb
  5. Halo & L.E.D.
  9. TOOLS REQUIRE
  12. Crimper/Pliers
  21. STEP:
  26. STEP:
  27. PLS VOTE ME
BMW e46 HID Headlight Replace
Nov 23, 2012 | 2000 GMC Denali
Lt. headlight low beam wont work after replacing the bulb.
I assume it didn't work before you changed the bulb either. You'll have to check for voltage at the bulb socket when the low beam headlights are turned on. If there is none you'll have to trace the wire back to where it splits from the right low beam headlight. If there is voltage there you have a problem with the new bulb.
Apr 10, 2011 | 1991 Lexus LS 400
How do you change front headlight blub 2008 sonata
how do you change front headlight blub 2008 sonata
Nov 28, 2009 | 2008 Hyundai Sonata
How to install hid on a bmw 325xi 2006
INSTALLATION GUIDE:
Projector Headlight
Halo & L.E.D.
Turn Signal Adaptor
TOOLS REQUIRE
10mm - 8mm socket
Philip Screwdriver
Crimper/Pliers
STEP:
STEP:
pls vote an diam giving you link also for better help BMW e46 HID Headlight Replace
Oct 15, 2009 | 2003 BMW 325
Halo 5 In. Boxed Recessed Light Fixture H5ICAT - 6 Pack Logo
73 people viewed this question
Top Halo Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Halo Toy Expert? Answer questions, earn points and help others
