Copy pages from book - Office Equipment & Supplies
  • 313 Answers
Depends on the copier most if you place the book under the doc feeder and put the first page to be copied with the edge on the position plate you copy theat page and then move the boo over so the centre is on the edge of the glass copying are it should copy that page .. if you hve a large copier if you put the book in the centre marker and select the combine book feature it will scan all the book put one page on one sheet and the other after .. can you put up the details of your machine for us
Posted on Jun 24, 2009
I MAKE A COPY AND I GET MY COPY BUT I ALSO GET A BLANK SHEET.
See if your copier has "Book mode" if so it's scanning you original and looking and scanning for an open book, i.e. page left on glass and page Right (two) on glass. Like you had a book flattened out on the glass. Make any since? #2 possible malfunction in print button. #3. Are sheets coming out stuck together or do they appear to be two separate scans?
Feb 04, 2016 | Cannon Office Equipment & Supplies
Copying or scanning from books
Check in you scanner settings there should be the single sheet feeding setting check that is not selected
Jul 24, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
How do you copy a book on a Sharp MX-503N Copier
Hi
If you go here:- MX M503N MXM503N Digital Copier Printer Archive Sharp you will get to a page with a list of manuals etc which you can download in pdf formet and which you will be able to use to find out how to do what you want. If you search "book", then there are a variety of options that are described.
I think you should be aware that copying a book in this way is subject to copyright laws.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 11, 2015 | Sharp Office Equipment & Supplies
I have created a 1-page document (colored green with print) to use as a book cover. I can save the document but cannot copy/paste it to the first page of a different document (my manuscript). How is
Y ou mentioned that y ou have created a green page but not how you made it ....
Have y ou tried ti simply create an image and insert TNA image on tour first page ? Y ou clan adjust The seize of The image to fit The entire page
Aug 13, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Black vertical line when copying a book page.no light leaks.
If it is along the edge of the print, it may be the edge of the book page you are seeing. if it is going through the text of the page, your scan carriage is likely skipping. If you don't see this on copies of single sheets of paper laid on the glass, then the weight of the book may be deforming the glass enough to catch the scan carriage as it passes. If you see it on single copied sheets, there is probably something on one of the scan rails under the glass that the carriage is "hopping" over as it passes. You could try watching the scan carriage move while holding the lid open to see if the carriage "hops" once during a scan.
Nov 10, 2013 | Panasonic KXMB2030 AllInOne Printer
I'm trying to photocopy a book on a canon imagerunner 5075 without copying one page at a time and flipping the book around. Is there a way where the copier scans the right page and then scans the left page...
Hi Kim,
there are a couple of easy ways to tackle this problem. you have a book that when the spline is opened exposes 2 pages to the glass for the possibility of copying. What YOU need to determine is whether or not you want page 1 to ouput seperately from page 2, or , would you like page one to be on one side and page 2 to be on the second side. In other words auto duplex. That decision determines which feature you will use. I will walk you thru both. I realize you want the copier to scan the first page and then scan the second without you having to move the book around. I'm thinking you would be happy if the copier did that very thing and you wound up with a 2 sided copy with page 1 on the front and page 2 on the back. Here we go. Fom the main copy display locate the 2 sided button and select it. Select "book 2 sided" and follow the prompts. You could actually copy the entire book this way and when you are thru press "done" and here comes the avalanche!
If you want the images 1 sided on seperate sheets (not sure why) you can select "special features" from the display in the lower right corner and select "2 page seperation". same drill.
Apr 25, 2011 | Canon imageRUNNER 5000 Copier
How to have multi inserts with 100 page book and make the copy come out like the book?
If your printer equiped with ADF( Automatic Document Feeder ) then use it. Just remove staple wires in the middle of the book and put it in ADF and start copying
Jan 06, 2011 | Office Equipment & Supplies
Tried to copy a book and the copier started pages were blank
maybe it would help if you try not to use the automatic paper select button or use the manual paper select try. set it to 11 x 8.5
Jan 31, 2010 | Canon Office Equipment & Supplies
Scanner problems on HP Photosmart C4180
you need to lee at your printer seting
Nov 18, 2008 | Office Equipment & Supplies
Photocopying a book
yes, there is a button for book form.
it will either be in additional functions or duplex mode.
when copying leave book open on glass it will scan the first page then scan the other page. you can have it on two different sheets or one double sided sheet.
Good luck.
p.s.: it should be in the user manual also if you have it.
Nov 15, 2007 | Canon imageRUNNER 5000 Copier
137 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
