Question about Frigidaire Refrigerators
PROBLEMS FGHC2355PF COUNTER DEPTH
  • Frigidaire
    Frigidaire May 15, 2014
    Good Afternoon Friend, I understand that you are having problems with your Frigidaire refrigerator, model# FGHC2355PF. If you would please elaborate on what is going on with your refrigerator, so I am able to better assist you. Looking forward to hearing from you. WP
Is there a standard size for a kitchen countertop?
A linear foot is 12 inches wide and 25 inches deep because the standard depth of kitchen countertops is 25 inches.
The Americans with Disabilities Act Accessible Guidelines state that space at least 30 inches wide should be accessible, meaning that wheelchair users can roll up to the counter to perform tasks. The counter should be between 28 and 34 inches high and accommodate a minimum 27-inch knee clearance below the counter, sink or cabinet space. Anything beyond the first 16 inches of counter depth, from the front edge, is considered dead space for wheelchair users.
Apr 09, 2018 | Kitchen Ranges
Tip
New Refrigerator and Refrigerator Depth
When buying a new refrigerator many people like the look of a built-in refrigerator but find that they are very expensive and will require extensive remodeling to make them work for their kitchen. The answer becomes the counter depth refrigerator. These refrigerators depth can vary in the depth between 23 and 27 inches. This will keep the front of the refrigerator back about six inches more than a normal refrigerator which often run between 30 to 34 inches in depth. While the front of the counter depth refrigerator may still have to stick out beyond the cabinets so that the door can be opened, it does not require that it stick out way beyond the cabinets, as many normal depth refrigerators do.
The configuration of many counter depth refrigerators is the double side by side door model with a freezer the full length on one side and the fridge on the other side. They also come with the freezer in a drawer on the bottom and a double door fridge on the top.
Because of the depth limitation many of the counter depth refrigerators are wider and/ or taller then the standard depth models. This gives the room for the refrigerator cu ft or refrigerator cubic feet (internal size or capacity) to be larger with less depth. If you are considering one of these models, make sure that you measure the space available to make sure that you can fit the refrigerator into the hole that you have for it.
The price of the counter depth refrigerator will also be a bit more then the standard depth refrigerator. While this cost may be more, they are still much less then a true built-in refrigerator. If you check you can also find counter depth refrigerators that will allow you to customize the front panels with wood, just like true built-in refrigerators.
What refrigerator best meets your needs can only be decided by you. A new refrigerator will often last about 15 years. Take the time to check carefully into what type and size will be the best for you.
http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
http://www.fixya.com/support/r4327013-refrigerator_efficiency
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
on Mar 13, 2010 | Refrigerators
Problem with counter depth.
Get a nipple and a sleeve and put the nipple on one end of the sleeve and then scew the sleeve onto the shank.
May 02, 2013 | Plumbing
Ice maker quit working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
reyqyte
May 22, 2010 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
The ice maker stopped working
heatman101
Dec 01, 2009 | Kenmore 23.1 cu. ft. Side-By-Side Counter...
GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Jul 05, 2009 | GE GSH22JFR Side by Side Refrigerator
Clearance for Jenn-air counter depth
for proper air ciirculation its always good to have as much air circlation as possible that would in turn give your appliance longer life the least amount of space would be at least 2-3 inches all around.
Jan 01, 2008 | Jenn-Air JFC2087HRP Side by Side...
KitchenAid Refrigerator 42 in counter depth freezer problems.
It sounds like the defrost timer may be bad,or you might want to ohm out the heater itself. And the only othe part is the terminator witch sounds like you replaced that allready. I would check the heater and if that is good replace the timer itself. Hope this helps
Jul 13, 2007 | KitchenAid 20.3 cu.ft. Counter-Depth...
Refrigerators Logo
18 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
