Question about Freezers
Old side by side defy duette S640
The compresor is running and getting verry hot I can turn it on and off using the thermostat but no chill is getting into the freazer.There is a red light shining over a tryangel with a {!} whot dose this mean? The fridge has a seperate compresser that do's not get as hot but is workihg fine. There is a red light over a tryangle with a [!] in it wat dos this mean?
3 Suggested Answers
SOURCE: DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Posted on Sep 11, 2009
bobicehouse
  • 1524 Answers
SOURCE: I have comercial freazer True 49.Compresor make
You have non-condensables in the system.
1.Recover Refrigerant
2.Change Drier
3. Evacuate to 500 Microns
4. Weigh in charge
Posted on Dec 03, 2010
Hi there my freezer doesnt seem to be freezing properly had water in didnt freeze for 3days in fast freeze also hae ice pos some are freezing some arnt.... 2.5yrs old only plae help
you could try turning up the control to the thermostat to a higher number its likley to ne at the back of the unit try to find it near the compresor or change the thermostat,,as yours is not working right
Jun 24, 2010 | Freezers
I have an aman side by side refriguerator its
maually defrost whole unit.no hot water.the tube is the drain.make sure not blocked.otherwise it will ice up again
Feb 13, 2010 | Freezers
Sep 11, 2009 | Freezers
Everthing sunddenly thawed out how come? whats the fix can i do it my self
If you heard the compresor running and it's not cooling ,probably is out of refrigerant(freon) ,but ifthere's power in the outlet and the compresor isn't working and is hot to the touch ,could be the relay or the compresor went bad ,also if there's power but the compresor is cold it could be the thermostat is open ( you can check it by putting a jumper in the thermostat wires).
Aug 20, 2009 | Frigidaire Freezers
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 | Freezers
Freezer runs all the time
I don't have enough information. Use a freezer thermometer and check the temp. If below 0 probably a bad thermostat. Sides getting hot is normal. Thats how it gets rid of the heat from inside. In the summer a freezer can run over 80% of the time. Again this is normal. Another thing to check is the gasket around the door. See if it is worn or torn and is sealing properly. If there are condensor coils under neath clean them check to see if the fan under there is working when compressor is running. (Not all freezers have coils underneath. Some have them in back, Smaller units just use the side of the cabinet.)
Jun 26, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
176 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
