Washing machine takes long during wash cycles and does not take hot water through red pipe .
  • 57 Answers
Check your water supply at the washer tap and your problem is fixed as the machine is taking so long because its heating cold water up
Posted on Jun 23, 2009
No hot water during wash
remove the hot water pipe from the washing machine and check whether there is a blockage at the inlet of the pipe. also check whether the hot water is coming from the tap.
Apr 24, 2016 | Washing Machines
Washer only washes with hot water
consult your owner manual about you are unsure about if the machine is acting anormally
Some machines, is running hot water during cycles, other cold water during cycles.
God bless you
Jul 18, 2012 | Washing Machines
Changing washing machine heating elemant
washers dont have heating elements, they use hot water from the hot water tank, most likely clogged screen at either end of the hot water hose, replace or clean screen(s) check for screen at water valve, bad,weak or burned solenoid on water valve, replace valve, reason wash cycle is long----- water restriction during fill and rinse cycles they are controlled by the water level switch
Jul 09, 2012 | Washing Machines
Inlet water valve error when the door is opened and closed during a washing cycle
If water is siphoning out, either drain hose is too far down pipe or there is an airtight seal where drain hose goes into pipe.
Aug 31, 2017 | Washing Machines
When iput washing on it seems that the hotwater isnt hot the pipes are on ive checked
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on.Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace the Valve.
Nov 30, 2010 | Hotpoint Aquarius WD640 Front Load...
Water drains during wash cycle. I have used this washer for many years without a problem. About two months ago I noticed that the water level in the drum was going down during the wash cycle. Last week I...
Take the drain hose out of the drain pipe and put it into a sink to test the machine
If that works make sure that the drain hose is being allowed to breath (ie let air into the main drain pipe so that the machine does not set up a syphon).
Jul 16, 2009 | Whirlpool Washing Machines
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Hot water goes into cold water washes
Jan 12, 2009 | LG WM-1832C Front Load Washer
Washing Machines Logo
268 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
