Question about Sony Cyber-Shot DSC-P32 Digital Camera
Fix battery contact
How do I fix the battery contact?
Set 2
1) you must replace batteries with the same type alkaline, and see if there with the same polarities, can be some possibilites for wrong polarity.
2) clean the contacts battery with c. cleaner
3) retigh the spring contacts battery with long plier for better contacts
4) open the remote c, and clean the keypads for dirty, corrosion, oxide and bad contact. fix it
5) Try again
6) reset the code again
7) if the problem persist go to the repair shop TV for fix it.
God bless you
Oct 15, 2012 | Televison & Video
Urc4220 not working
1) reset the code again
2) change the batteries by new ones, with the same type and right batteries, use only ALKALINE, not combine.
3) see if are wrong polarities
4)retigh the spring contacts batteries with long pliers for better contacts.
5) open the r.control clean the KEYPADS, for oxide,bad contacts, corrosion and fix it.
6) try again, if doesnot resolve the problem , go to the repair shop for fix it, or replace.
God bless you
Sep 22, 2012 | One For All URC4220 Remote Control
How to fix digital stream remote control
1) try to change a new batteries by the same type of batteries and full charged
2) clean the contacts battery with contacts cleaner
3) retight the springs contacts battery with pliers for better contacts
4) resolder the wires contacts battery
5) open the remote control and clean the keypads switchs with contacts cleaner for dirty, dust, oxide, bad contacts, open contact with VOM and fix it. Remember they receive signal from Syscon and emite infrared signal to the receiver
Otherwise you mus go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Televison & Video
Carrier rv air conditioner
1) replace batteries by new ones type ALKALINE
2) CLEAN the contacts batteries with contacts batteries
3) retight the spring contacts batteries for better contacts.
4) if doesnot work, open the remote.control and clean the keypads contacts from dirty, dust, oxide, or bad contacts or open contacts repair.Remember they send infrared light to the receiver Syscon
5) Otherwise you must go to the repair shop TV for fix it.
God bless you. see the diagram
Jul 29, 2012 | Televison & Video
Frozen screen
1) clean the contacts batteries from dirty, oxide, with specail spray clean contacts.
2) resolder the wires contact batteries for a GOOD contacts.
3) tight the Ribbon cables 4) Tight the wires connector from display board vs lower board see the block
5) Adjust the REED switch, clean it, and tight the wire connector, see the diagram 6) After you fix it , RUN the software calibration for diagnose and fix it.
God bless you
Jun 28, 2012 | Universal Remote Control MX6000 Remote...
Manual channel search not available
1) change the batteries by new ones.
2) Clean very well the contacts batteries with special spray contact cleaner
3) Retight the sprigs contact batteries, for better contacts.
4) RESOLDER the wires contact batteries.
5) Reset the code again go www. fitness. manualsonline.com or www. remotecodelist. com and download free.
6) If doesnot work, you must go to repair shop for fix it.
God bless you.
May 13, 2012 | Sanyo Televison & Video
Pentax optio e85 will not charge battery
1) If your battery is charged separately (removing out of the camera) then try to plug in the contact properly, move it there and back to see if the indicator light changes its color. Sometimes cheap batteries, or chargers lose contact - you should open, find any lose contact and fix. For fixing lithium batteries rubber gloves and eye-protecting glasses are compulsory.
2) If your battery is charged inside of the camera - try to open the camera with a screwdriver and check for any lose contact, move it there and back until some indicator shows that the battery is finally charging. If you can't fix it yourself - a specialized mechanic will help you. Don't be afraid to bring him a disassembled battery.
3) If you conclude that the battery is dead - buy a new one on ebay.com or elsewhere. Remember that original manufacturer's batteries are sometimes more reliable but much more expensive than non-original batteries.
P.S. If this helped you to solve the problem (or at least brought some clarification) - rate this solution with 4 thumbs up! But before you would give a negative rating - post a comment, so I could improve my solution to satisfy your needs. Thank you!
Mar 07, 2011 | Cameras
Not responding to recharge
Mar 05, 2011 | Cameras
I dont seem to have any power going to my key board
I just bought and installed this keyboard. I experienced two issues, both easy enough to resolve. 1. The included batteries were dead, fix was new batteries. 2. While installing the batteries I discovered that the contacts for the + end were not making contact, fix was to gently bend the contacts out so that they would make proper contact. Keyboard works like a son of a gun. Quality and bang 4 buck is A++....
Oct 02, 2009 | Fellowes (98917) Keyboard
I have an Eclissi watch i purchased at Costco. I got the back off to change the battery but cannot get the battery out. this is my first attempt at changing a battery and do not want to break anything. Is...
Batteries are usually held in place by contacts. Contacts are screwed by the 1-2 small screws into the movement.
Some contacts are fixed by 'clip-on' assembly.
Depending on what type of contact you have: unscrew the screws or unclip the end of the contact- the battery will come loose.
In case if the battery still very tightly fit after releasing contact, get some sharp pointed tweezers and pry up the battery by force.
Do not forget to rate, please.
Jan 27, 2009 | Watches
Sony Cyber-Shot DSC-P32 Digital Camera Logo
29 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
