Question about Billcon D-551 Mixed Money Counter 2 Pocket
How to fix error 7a on a billcon d-551 - Billcon D-551 Mixed Money Counter 2 Pocket
  • 343 Answers
I know this is an old post. But the Error 7A on a model D-551 is a "Gate Up" problem. The gate is what diverts the note to the reject pocket or the lower stacker area. 1) Check that the gate flap can be moved smoothly. The solenoid that electrically moves the gate flap is connected on the main control board (under the right cover) at CN14. Re-seat the plug cable. Also clean ALL the count sensors inside the machine. Good luck
Posted on Feb 02, 2015
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
ERROR E38
Found manual here with all error codes. It's in Russian though..
http://www.rservice.by/files/manual/cassida/counters/Cassida%20Billcon%20N120%20User%20Manual%2028.11.2013.pdf
Mar 24, 2014 | Billcon N-131 Money Counter
Error Writing Data (551-00000310 41329c5c)
Read only Means it may not burn a DVD but only CD-RW
Maybe the problem is the dvd is only rom not RW(read write)
Oct 24, 2013 | Computers & Internet
Brother MFC-8440 Machine Error Code 7A - tried to print something and machine stopped, beeped and gave me this code. No resolution from Brother other than to have a tech come look at it. Any insight...
Hello thanks for using FixYa
Error code 7A occurs in different forms and they are linked directly to errors caused due to calculations as detected by GPU, however, it is still doubtful what exactly cause these GPU errors in hardware and the errors in WU. Keep in mind that this error code could also suggest that the main PCB is broken.
For the error code 7A to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition. If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor. In this case, make sure that there is no mechanical load present on the main board. While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Feb 14, 2011 | Brother MFC-8440 All-In-One Laser Printer
Machine error 7A
Brother printer error code 7a occurs when the main motor fails to synchronize properly with the reference clock. for more information and help........
http://www.fixya.com/support/t5660619-7a_error
Mar 04, 2010 | Brother MFC-8440 All-In-One Laser Printer
Machine Error 7A and the machine say unplug machine
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
Nov 25, 2009 | Brother Office Equipment & Supplies
When i turn on my brother mfc 8440 it is saying
Oct 01, 2009 | Brother MFC-8440 All-In-One Laser Printer
ERROR 7A
May 07, 2008 | Brother MFC 8820D All-In-One Laser Printer
Brother laser mcf-8440/ machin error 7a
Oct 26, 2007 | Office Equipment & Supplies
Billcon D-551 Mixed Money Counter 2 Pocket Logo
1,076 people viewed this question
Top Billcon Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Billcon Retail Supply Expert? Answer questions, earn points and help others
