Question about Samsung Remote Control
The TV is displaying picture but no sound
It's a vivid and there was nothing wrong earlier I still have picture no sound
Vivid manuals
If you are hooked up to cable ?
Try a factory reset to default and a new channel search scan
Apr 26, 2014 | Televison & Video
Best picture settings
Best picture is nothing but the picture which is comfortable to your eyes and pleases you to watch. You can either select a suitable picture mode like standard, dynamic or vivid or you can set the color, contrast, brightness and sharpness according to your liking.
Jan 16, 2014 | Samsung UN46D6050 TV
Dell laptop via HDMI cable to Vivid TV stopped working
If your TV setup has settings for TV 1, TV 2, etc., try changing the TV number setting to see if that will work.
Good luck with it.
Cheers!-a.
Jun 06, 2012 | Computers & Internet
Vivid mini hi fi wont turn on
when you plug it in it goes into stand by mode automatically, the LCD display will be lit and you can set the time but nothing else will function. you have to hit the on/standby button to turn it on.
Feb 04, 2012 | Audio Players & Recorders
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
No power to TV. No sound, no picture.
frist you need to check the fuse it is inside of tv by the power cord looks like this maybe a Panasonic tv did notsee any model number so i will gess as to what is wrong check fuse if blown need to replace with a white glass looking fuse of same value like i said dont know what model number this set is but the thermister could be at falt for the fuse to blow.
Mar 14, 2009 | Panasonic Televison & Video
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
Dark picture
you know it sounds like the same problem i had....
look this is something you can try.... "turn the tv off and unplugg it!!!"...you'll need to take out the lower front part of the tv......(where the speakers are to be exact) on each lower end you will find 2 screws..Be careful it will open to the side and there are many wires, i suggest you mark them to know where to put them back...then right in the middle there will be a black cover with about 5 screws..take them out....and look at the very bottom you'll see a thing with 6 pegs....the top ones are for the screen "DO NOT TOUCH THEM"...the ones on the bottom are for the colors...re adjust them...the left one it's for blue, the middle one it's for green and the last one it's for red...
I had the same problem after i moved....and after i re adjust that the tv looks super...
i hope that helps..:P
Sep 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Dark picture
sony had a recall on this set see if this is one of yours
http://esupport.sony.com/perl/news-item.pl?news_id=24
Oct 01, 2007 | Sony KP-57HW40 57" Rear Projection...
Samsung Remote Control Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
