Question about Dyson DC14 Bagless Upright Cyclonic Vacuum
Can i fix or replace cyclone release button - Dyson DC14 Bagless Upright Cyclonic Vacuum
Instructions on how to replace the DC17 cyclone release catch
Hi Craig,
This isn't a part that we would recommend fixing yourself as there is risk of further damage to the product.
Please make contact with Dyson directly and give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
Thanks
Allan
Oct 30, 2015 | Dyson Dc17 Cyclone Release Catch, Part...
What does the spring connect to in the release button for the cyclone?
Hi Roxanne
The spring is typically located beneath the button which you press to release the bin door.
If you have experienced a failure of some kind, I would suggest contacting us directly via the Dyson Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
All the best,
Allan
Oct 04, 2015 | Dyson DC17 Animal Bagless Upright Cyclonic...
DC07 Vacuum canister stuck. I won't release so I can empty it. Any suggestions?
You may have to press the release button and hold it depressed as you pry the canister loose.
Feb 13, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
The dust collecter is stuck and won't release from the vaccum. how do i release it to empty.
Make sure you switch off the vacuum cleaner.
Here is the instruction to remove the bin
Press the cyclone release catch with your thumb to remove the
clear binTM assembly from the machine.
• When removing bin, do not pull up on carry handle while pressing cyclone release catch
• When replacing the bin, ensure it clicks back into place.
Dec 31, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Cyclone Release
Hi Barry, it's Jack at Dyson.
I'm sorry to hear about the difficulty you've had with the bin and cyclone on your machine. We'd like to learn a bit more by taking you through some troubleshooting checks when you have the vacuum easily to hand. It may be a simple fix.
You can reach us by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 13, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dyson dc17 won't turn on and stay on unless you hold the red button on?
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
Jun 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do i empty my dyson dc07
Hi its Darran at Dyson.
Remove the bin and cyclone assembyl by pressing the release button above the word Dyson on the carrying handle towards the machine.
Then hold the bin and cyclone assembly over a dustbin and pull the trigger located underneath the carrying handle which will release the bin base to empty the dust and debris from the bin.
I hope this information is useful to you and should you need any further help or advice, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Feb 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
HOW DO YOU EMPTY THE BIN ON A dc07
Grasp the handle on top of the cyclone, then press the button which will be just by your thumb. That releases the cyclone (with bin attached) from the rest of the machine. Then unscrew the cyclone from the bin. Job done.
Dec 22, 2009 | Vacuums
Pulling up on button will not release bottom of cannister.
The gasket is sticking to the dump lid. While holding it over a waste receptacle, operate the release button and pull the waste gate at the same time. Rinse the canister and dry thoroughly. Apply a spray of silicone to the gasket surface, let it sit for a minute, and wipe off the excess with a paper towel. This should fix you up.
Best regards, --W/D--
Aug 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC14 Bagless Upright Cyclonic Vacuum Logo
42 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
