Icematic model no. n131m works for 2 hours and the second red light comes on, and the machine stops working. what should i do
fellowesrep
  • 102 Answers
SOURCE: Achiever Shredder
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
SOURCE: Machine will not come on
Hi there
Sounds like a typical Ballast ( lamp's powersupply ) problem.
Posted on Mar 26, 2008
SOURCE: my philips 37in lcd hdty
this sound like a power board problem they are nt that expensive if you do i yourself or a coud tech can fin what is exaclty worng on the board and fix or you cn cange the whole thing.
Posted on Nov 07, 2008
  • 39 Answers
SOURCE: dehumidifier fails to start.
it should be a float whitch..somewhere around that bucket....take a look, sounds like it stuck ..and tripping whole system
Posted on Aug 25, 2009
SOURCE: MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Posted on Sep 24, 2009
Why does my washer stop working in the middle of wash cycle and then go dead and no response?
Should get some one to look at it. If there is a hot smell could be a short someplace.
Dec 22, 2016 | Kenmore Washing Machines
We replaced a pc board on a Icematic N131M, but no freezing takes place
check senors and check refrigeration unit
does compressor start
does condenser fan start
is condenser clean
disconnect hot gas valve
i see you are not a fridge tech like me better to get help with it
Feb 14, 2014 | Kitchen Appliances - Others
Icematic n131m
The more activity the freezer and fridge see, the more cold escapes. If the freezer defrost system gets issues (broken defrost heat coil, stopped up vents, frozen peas in coils) things slow down. Find the defrost timer and mark the knob on it with white-out to see if it moves. It moves very slowly, one rotation a day.
Nov 26, 2013 | Kitchen Appliances - Others
I'm having problem with my icematic 132M . I freezes the cubes allright , but the cubes doesnt fall out before the harvest stops, so the cubes is still hanging on in the machine which causes the m
First i would clean the machine per manufacturers instructions with nickel safe cleaner and sanitizer. When the plates get dirty it will cause ice to hang on to plate. Also check the thickness of ice if to thick it will not come off plate.
Oct 08, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
My indesit idl has stopped working. The red light comes on but none of the green setting lights come on - any ideas
Led 1= Prewash / 3hr
Led 2= Wash / 6hr
Led 3= Rinses / 9 hr
Led 4= Drying / 12hr
LED. illuminated
1 = Overflow ( water in base )
tip machine back. does water come out? if so you have a leak, possibly from bottom spray arm nut or loose salt pot. see if they are loose. if not, remove the base, put dishwasher on a block of wood, shine torch underneath to see where the leak is.
1+2 = Pump timeout, or Software recognition error ( timer not programmed, wrong keypad)
1+3 = Circulation pump not working
2+3 = Not filling
2+4 = Heating circuit not working
2 = Solenoid valve 'broken'
3 = Thermistor (NTC) cicuit not working
4 = Temp not reached whilst heating ( poss NTC detached from casing).
remove door panel. ntc is attatched to the rear of dispenser, a little white thing with 2 black wires on it. refit to the clip on the dispenser.
It is usually necessary to 'reset' the machine after a fault code has been displayed. Resetting.
Switch dishwasher OFF, rotate the selector switch to STOP/CHANGE and switch on, after a few seconds the LEDS will go out enabling a new programme to be selected
Aug 20, 2011 | Dishwashers
I have an icematic n45s but it's not making ice and it was second hand so dont have the service manual. Does anyone know if there is anything i can do or do i need to get a repair guy out?
i have a icematic F120 and 2 of the 3 led`s are on (the no water led and too hi-loww cond temp 3`stand by) Does anyone know what is the problem.!?
Sep 18, 2009 | Freezers
I Can`t switch my headset on, and it stops charging after 20 secs
Move the call control button up or down, the indicator light will flash blue if it's paired or blue and red. If it flashes blue and red you need to pair phone with the headset. the passkey is 0000.
Jun 17, 2009 | Plantronics Explorer 340 Wireless Headset
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
