I have an insect killer model no. Z27886-BS the bulb is blowen where can i get a replacement bulb for this item?
The bulb seems to b blew is it possible to get a replacement bulb operating voltage 220 - 240~50Hz power max; 5 Watt
Yes it is! Lloytron F4T5BL 4 Watt on Amazon or Ebay 5 pound approx. There are other makes of higher waltage
Posted on Jul 11, 2014
Have a Hunter model 28675 ceiling fan with two light fixture. Turned lights on, heard a pop. One of the bulbs blew, turned black. Now the lights will not work with new bulbs.
Is the fan and light kit equipped with a wireless remote control? If so a short in the light fixture sockets will cause a backfeed into the electronic circuit boards of the remote controls receiver and burn it out. If you have a voltage tester or pigtail with a light bulb remove the screws for the light kit and disconnect the two wires from it. Connect your voltmeter or pigtail to the two wires that were connected to the light kit. Have someone turn on switch for light or push light button on remote and see if you are getting power, If you are then problem is in light kit. If no power is present then receiver for remote is burnt out. Depending on the fan receiver can be built into the fan or located inside the top canopy and can be easily replaced. As per the light kit having a watt regulator it is possible that was installed to prevent overheating of the sockets by the manufacturer. That can also have blown out causing no power to get to the bulbs. If you have power at the wires that connect to the light kit then the watt regulator is defective. You can bypass the part but you must insure that you do not install bulbs that are of a higher wattage then what the fixture is rated for. Or you can order a replacement from Hunter. Good luck.
Jan 27, 2018 | Electrical Supplies
Want to know power consumption of a hpsr5410f
The HP Pavilion w1907, 19 inch Widescreen monitor, RK283AA,
uses 49 Watts in operating mode, 2 watts in sleep mode.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00916924&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3351967
The Compaq Presario SR5410F Desktop PC, has a 250 Watt power supply. (Maximum wattage rating )
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01374067&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3686678
Theoretically.
Back in the day when this computer was made, Power Supply manufacturers were 'fudging' a bit on the truth.
(HP has their Power Supply's made by another company.
Bestec, HiPro, and Delta, are three of them )
Actual wattage is more like 60 to 70 percent, of what is stated.
250 divided by 10 = 25.
25 times 6 = 150 (60 percent)
25 times 7 = 175 (70 percent)
Your Power Supply's actual maximum rated wattage, may be as low as 150 Watts!
Going with the Power Supply produces a maximum of 250 Watts;
If you are playing an intense game, or have several programs running at once, you MAY reach using 250 Watts.
Just surfing the internet? About 100 Watts.
Desktop PC plus Monitor:
1) Surfing Internet: 149 Watts, or let's just say - 150 Watts
2) Computer is maxed out running hard?
249 Watts, or let's just say 300 Watts.
Voltage times Amperage = Wattage
Wattage divided by Voltage = Amperage
Number 1 above? About the power it takes to use a 100 Watt light bulb, and a 50 Watt light bulb. (Incandescent)
Number 2? About the power it takes to run three 100 Watt light bulbs.
(Incandescent)
Regards,
joecoolvette
Apr 16, 2012 | HP SR5410F 18GHz Presario Pentium Desktop...
I NEED A REPLACEMENT TIMER (PB912M10).
1.remove timer from power pack. this includes all wiring to timer and switch.
2. buy a timer at Home depot.
3. plug power pack into timer,
4. reattach low voltage output wires to garden lighting system or whatever you use the low voltage for.
this is the second time I had to do this remedy. the timer that comes with the power pack really stinks!
Feb 08, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
I need the red clip that sets the timer to come on it broke . is this posible
1) There is one and only one type of plastic Intermatic tripper on the market.
These trippers are red and green.
See at Amazon:
http://www.amazon.com/s/?ie=UTF8&keywords=intermatic+timer+trippers&tag=googhydr-20&index=aps&hvadid=5156211581&ref=pd_sl_1b2t69w1k6_b
2) You posted under 121 Watt low voltage power pack. I search timers every day, and link above shows only plastic Intermatic tripper available, and it fits Intermatic outdoor mechanical timers, but my understanding, does not fit power packs.
Please add a comment and say if these trippers match your product so others can benefit from your important experience.
Please also include exactly which product you have, so that folks with expensive products that don't work are given accurate free information.
3) I have searched Malibulights.com, Intermatic, ebay, amazon, etc and have been unable to find trippers or parts for power packs.
However 'Harry' wrote fixya with a work-around.
He bought cheap plug-in timer, put his power pack on override, and then plugged power pack into cheap timer.
Harry also said his power pack has 5 year warranty and he was negotiating with Malibu for warranty replacement. No word how that came out.
4) Best I found are tips for next power pack that might save money:
The reason I add tips now, before your power pack needs replacement is some fella wrote fixya.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
a) Match wattage of bulbs with wattage of power pack
Lets say you have fifteen 20 watt bulbs = 300 watts, so install 300Watt power pack
b) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
c) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
d) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 04, 2011 | Malibu Intermatic Inc. ML121RT Low...
Clock runs, but time quit. What is "plastic Ho"?
You posted under Malibu Power Pack.
If you have different timer, then instructions below will not fit your question.
1) If I understand correctly, you can manually turn malibu low-voltage lights on-off but timer is not working.
2) 'Harry' wrote fixya with a work-around. He bought cheap plug-in timer. Set power pack to override and then plugged power pack into cheap timer.
3) Harry also said he has 5 year warranty and was negotiating with malibulights.com for refund.
4) Other than Harry's solution, I have not been able to find repairs and parts for power packs.
Hours of searching Malibu, Intermatic, ebay etc turned up a few folks who took their power pack apart, but nobody reported they fixed a power pack once it goes bad.
5) The best I found are tips for next power pack that might save money:
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
6) Add a comment for more free help.
Jan 20, 2011 | Malibu ML200RT - Low Voltage Power Pack...
I had a brief power outage at my house and now the timer isn't tracking the time. It seems stuck. How do I fix it?
Try unplugging power pack and see if it resets.
A lot of folks write fixya with power pack problems.
There are no repair parts, although guys write in and say they were able to take the unit apart, nobody reports being able to repair a power pack once it goes bad.
Also I have searched Malibulights, Intermatic, e-bay etc for parts and repair information.
There seems to be no way to repair power packs.
Maybe you will come across a great solution and add a comment so we can help others.
'Harry' wrote in with a work around: He bought a cheap plug-in timer, set Power Pack on override, then plugged Power Pack into cheap timer.
Harry also said his Power Pack was defective within the 5-year warranty.
He was negotiating with malibulights,com for a refund.
After hours searching for solutions, the best I found were tips for next power pack that might save money:
1) Match wattage of bulbs with wattage of power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
Jan 19, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Clock not working??
I answer questions for free.
I specialize in timers and electrical devices.
I hesitate to answer about Malibu power packs because there are no parts or repairs for a power pack. And then the customer is sour because fixya seems to advertise a solution, which is misleading.
Here's what I've done for fixya customers.
For hours, I searched Intermatic Timers, Malibulights.com, and the web looking for parts and solutions for the Malibu power pack. There are no parts or solutions.
I purchased a power pack from Home Depot and examined it and then read the manual from head to toe.
The answer is this: if the power pack is not working and the receptacle has power, then the power pack is busted and you need another one.
However I can save you on your next power pack, and that may be worth money to you:
Your next power pack:
1) Match up wattage of bulbs with wattage of power pack.
15 - 20 watt bulbs = 300 watts = 300 watt power pack ... if you buy the 500 watt power pack for 300Waats of bulbs, then it will burn up the power pack.
2) Replace bulbs as soon as they burn out or other bulbs will burn out and the power pack will burn out
3) When working on bulbs, unplug power pack or the power pack may burn out
4) Use the link below to help plan your low-voltage lighting
Nov 02, 2010 | Malibu ML200RT - Low Voltage Power Pack...
My Malibu 200 Watt Power Pack/Transformer & Timer - ML200RT powers up but won't turn on lights. Is there a fuse that can be replaced in the unit?
There is no fuse and no repair parts
I've been all over the Malibulights.com website looking for anything that might help the large number of people with Malibu questions. The website has very little information and no parts and the site offers no help except the following:
1) Malibu gets the customer money, and other people troubleshoot for their customers
2) When buying a power pack, the total bulb wattage on the line has to match the power pack wattage
10 - 20 watt bulbs = 200 Watt power pack
15 -20 watt bulbs = 300 Watt power pack
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack.aspx
If your power pack is oversized, it will burn out the bulbs and burn out the power pack
3) A power pack makes a humming noise when it has power >>> check your power source if power pack won't work >>> no other troubleshooting is offered
4) Replace burned out bulbs ASAP or the power pack burns out the other bulbs
5) Unplug power pack when working on bulbs [otherwise, the power pack burns out which is why people write fixya asking why their power pack won't work after replacing all their bulbs]
6) Nowhere on the Malibu site does it offer-or-explain burned out power packs or power packs that don't work, but they show plenty of new products for you to buy.
Oct 18, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Transformer problem
Malibu power pack has to match total watts of bulbs
15 bulbs each 20 watt = 300 Watt power pack
10 bulbs each 20 watt = 200 Watt power pack
Mar 01, 2010 | Malibu ML200RTW - Low Voltage Power Pack...
Soldered in new fuse, blew it right away...whats a good upgrade?
A new power supply will fix your problem, and when the fuse blows do not replace it. It blows to protect your computer. please replace with a new power supply.
Oct 28, 2007 | Okia / 450-Watt / ATX / 80mm Fan /...
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
