Question about Acer Aspire Computers & Internet
What can i do to fix the Acer Aspire BlackScreen Problem for the internal Screen?
Some more Details: The Laptop crashed while i was running a game (no external monitor was connected) It kinda looked like this, but with random colors I restarted the Laptop, but the internal Screen stays black. External Dcreen with VGA = Same result, The screen gets no signal. BUT the HDMI connection works (with issues -> 4 big Vertical Dotted lines) Also i get a BlueScreen at the windows loading screen, than I'm trying to boot into the normal mode as long i have a some graphic drivers installed. (SafeMode works) Wthout the graphic drivers installed i can boot into the normal mode without any problems. In normal mode, at the Screen Settings, Windows only shows the PnP Screen (HDMI). I already read in other Topics, that the internal Graphic CHip might have some broken solder points, but before i open the laptop i wanted to make sure if there might be another way to fix it. I hope that there is someone who knows what part of the Laptop is having problems/ mght be damaged. Greetings and thanks in advance, LG! PS Sorry for the Wall of Text, but there is no way to add line breaks here! -.-
  • Acer Master
  • 16,852 Answers
Screen problems on laptops come down to three issues. Most common is the inverter, next is the cable that connects the screen to the motherboard and last is the motherboard. If you can see the image on the screen with a flashlight, it is not the cable or the motherboard.
Posted on Mar 03, 2017
  • 324 Answers
SOURCE: Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Posted on Feb 01, 2008
  • 1027 Answers
SOURCE: Acer Aspire 3680 bot issues
The problem is it is defaulting to lcd and not the external monitor
<FN><F5> to toggle to external
Posted on Jun 03, 2008
  • 748 Answers
SOURCE: HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Posted on Apr 08, 2009
  • 822 Answers
SOURCE: Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
Posted on May 20, 2009
  • 3153 Answers
SOURCE: connect broken laptop screen to external monitor
I would back mothmans answer 100% but might suggest you re-assemble the display to the laptop if you continue to have problems getting an external display going.
Posted on Sep 07, 2009
Acer aspire crashes and to reboots when i try to record video game footage
There is a good chance of still getting a blue screen with a OS upgrade. You should try a clean install. Then try testing the RAM. Leave one DIMM at a time and swap to one slot at a time. This may help identify a bad one.
Jan 30, 2013 | Acer Aspire Computers & Internet
Acer aspire 5750 black screen
My acer laptop 5750 went to blackscreen , even when turning off and on again, it kept black .
my solution is: Let your laptop on to drain your battery, once its drained, try turning on and feel if it doesn't have battery.
then charge your laptop for 4 hours, mine went back to work just fine
the display works fine 04/18/2014 good luck.
Aug 27, 2012 | Acer Computers & Internet
My lapptop Acer Aspire 5315 (Vista O/S) crashed. I
you can try hiren's BootCD, it's can fix MBR or re-format using this cd.
Dec 18, 2009 | Acer Aspire 5315 Notebook
Laptop won't boot. No splash screen. Crash
Take out any USB device from the PC when rebooting: some BIOSes will incorrectly try to boot off them.
If that doesn't work, enter the BIOS Setup (F2 or Del key at boot) and find the Boot Devices menu, confirm that the highest-priority one is "Internal HDD" (or the name of your internal hard disk).
Nov 07, 2009 | Acer Aspire 5670 Notebook
Acer laptop stuck on Aspire screen
i/run operatin disk take prompt comman and type chkdsk/rr 2-3 times it can be repair your system 2/ repair by operating disk if not work by two methode reinstal operating system.
Oct 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
My acer netbook crashed.. 2nd time to happen.. i had it fixed by an it person before.. I want to fix it myself, but need assistance. please advise.... the acer screen comes up, then the screen that says,...
Technically when your system crashed it's not easy to put it back again with details to details instruction, even guide cannot help out to that.
Maybe your Netbook have another problem aside on system crashing.
So it's difficult to say you can fix it in your own way.
Call a technician and ask after he fix it. I'm sure he will tell you and how to manage it.
Hope this tip might help you.
Oct 11, 2009 | Acer Aspire One PC Notebook
Laptop crashes
its not crashes, but if you do try to use recovery disk...
Jun 17, 2009 | Acer Aspire 5720 6497 Laptop
Annoying crash
Replace your graphics card or update the drivers to it...
Feb 28, 2009 | Acer Aspire 5002WLMi Notebook
Acer Aspire 5100 crashing
search the help fill on your pc for the fixed drive problem or try google
Nov 17, 2008 | Acer Aspire 5050 5430 Laptop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
