Question about Sharp ER-A330
E error code er a330 - Sharp ER-A330
My ER-A330 register wants to beep every time I try to ring anything up.
You forgot to sign on. It has no operator assigned. Enter your PIN number and press CASH# button in top corner of keyboard. If you have forgotten your PIN number for sign on, you can program new ones. One of the users has programming manuals here:
https://the-checkout-tech.com/manuals/cashregisters/Sharp7.php
May 24, 2016 | Sharp ER-A330 Electronic Cash Register
I have an ER A330 cash register that has crashed/locked up and will not respond when keys are pressed, help
turn the machine OFF, when it is on, by suddenly and sharply unplugging it from the power source.
Also unplug it from the network or computer or other system that it is attached to currently!
Leave it that way for 10 minutes.
Plug it back in.
Turn it on if it didn't turn itself on. Wait for it to initialize.
Nov 26, 2013 | Sharp ER-A330 Electronic Cash Register
Reprogramed tax after initializing Sharp ER-A330 now will not accept any sntry
I believe the ER-A330 has a Cashier # button - it should be labeled CASH #. It has to have a cashier signed on to ring a sale. Most owners forget that, because the same cashier stays signed in all the time, and nobody uses the button. If I'm right, all you have to do is this (in REG mode):
[CL] 1 [CASH #]
and start ringing your sale. The CL was to clear the error condition, if it was in one. 1 CASH # assigned Cashier #1 to the register.
The reason the register has the button is so it can track sales totals for each employee or shift. The register can be programed to stick with one cashier until another is signed on, or it can force you to sign on for every sale. At the end of the day it can print the normal Z totals by touching the CA/AT key, and touching the CASH# key gives totals for each cashier, I think.
Initializing the register cleared the cashier assignment and got you into the predicament. Touching the CASH # key twice will also clear the cashier assignment, as will resetting the Cashier totals with a Z reading. In any of those cases, just go back to REG and touch 1 CASH# again (or a different number if you want to sign on a different cashier).
Oct 23, 2012 | Sharp ER-A330 Cash Register
I got a er-a330 spcreen lights up do not operate please tell me what to do
Mea errors are quite common on those spcreens. Remove the flackinous gixmoid eroginator. This will give youa error, but it goes away quickly.
May 01, 2012 | Computers & Internet
Set time and date for sharp er a330
Turn Key to PRG mode (. = Dot / x = Multiply button)
Date setting
2610 -> [.] -> [x] -> XXYYZZ (Year-Month-Day/Day-Month-Year) --> [TL/NS]
Time setting
2611 --> [.] ---> [x] --> XXYY (XX Hours YY Min) ---> [TL/NS]
Oct 12, 2011 | Sharp ER-A330
Sharp er-a330 cash register prob'
The Sharp ER-A330 and ER-A310 both have a calculator function that turned out to be just trouble for users who don't need it and don't know how to turn it off. At the bottom-left of the keyboard is a button labeled PO. Normally you enter a dollar amount and touch that to Pay Out money from the till. On these models it also activates the calculator mode, allowing you to add and subtract numbers without affecting sales.Touch PO to turn calculator mode back off, and you'll have a cash register again.
Let me know if this isn't the fix you need.
Sep 26, 2009 | Monroe 2020Plus Calculator
ER-A330 SHARP CASH REGISTER PROGRAMMING MANUAL
The original English Manual has been discontinued. The only manual available is the German Version located here.
Mar 25, 2008 | Office Equipment & Supplies
Sharp ER-A330 Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
