Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
Do know where i can get a motor
My motor dont turn
Trueliving stand up fan manual
Probable motor failure
Jun 30, 2016 | Dryers
Replaced belt on dryer but drum wont turn even though motor is running
are you sure youve got the right belt for that model dont know if all belts are standard or not its a posibilty you have the wrong belt as im asuming your your turning the drum when empty when you get it over the drum and motor should be really tight hope this helps you
Jan 19, 2013 | Indesit IS70C Electric Dryer
My winshield wipers dont work on the steering wheel lever,but on the same the cruise button works , ive checked all the fuses the wiper moter, and seems like i dont know what to check next.
Check to see if you can hear the motor activating when you turn the switch on may be a bad motor or you have no voltage getting through to the motor.
Nov 17, 2010 | 1994 GMC Jimmy
ERROR CODE BLINKING,THE AIR CONDITIONER DOESNT WORK
it is happening due to blower motor not giving the signal to pcb pls check their is a return signal wire in blower motor is broken or motor is defective.
Jul 20, 2010 | Sanyo Split System Air Conditioner
Dryer randomly stops turning.Sometimes it turns and sometimes it doesnt! We have already changed the belt!Dont know what to do...
It sounds like the motor. A loud buzzing on startup is another sign of a motor. It could also be the timer. To check the motor, hole the door switch and the drum while having someone hit the start button. If it is easy to prevent the drum from turning the motor is bad.
Nov 27, 2009 | Refrigerators
The ac/heater wont turn on. i checked the fuses
It is possible but not very likely. check your floor console fuse block and look at fuse 25(blower) or fuse 26(temp motors)
Nov 21, 2009 | 2004 Buick Rendezvous
Sometimes won't turn over when i try it. 2003 cadillac cts
hi, when it dont turn over do you hear a clicking noise or is the engine turning over and just not starting.
If its the first and when you turn the key the starter motor dont turn the engine over allowing it to start you will usually hear a clicking noise and this is the selanoid inside the starter motor failing to make a connection.
If this is the case then all you need to do is get the starter motor replaced if you have any further comments or need further assistance then let me know ok
Aug 05, 2009 | 2003 Cadillac CTS
Need to replace the blower motor on my 2002 silverado
2002 silverado as follows :
1. if equipped , remove the sound insulator panel , remove the blower motor insulating cover screws , disconnect the electrical connector from the blower motor , remover the blower motor insulating cover , pull the retaining tab down while turning the blower motor counter clockwise in order to disengage the blower motor from the HVAC module , remove the blower motor .
2. to install blower motor , reverse the steps .
thanks for voting.
Dec 28, 2008 | 2001 Chevrolet Suburban
LG WFT7030TP
Trouble shooting a washing machine is easy but you have to know the sistem first if the washine machine take water wwell but dont do nothing eals could be a couple of things. The water level switch send curent to the water selenoids when the maching is empty then when the level of water reach the selected level the presure of the water active a presure swithc and the curent go to the timer there the timer send the curent to the motor, as you can see there are a procedure that you have to know to repair a washin machine and some instrument to trace continuity and curent warning disconect the machine frome ac outlet befor service .....good luck and rate me if you survive this riskey adventure...
Feb 17, 2008 | Washing Machines
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
16 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
