Question about HP Color LaserJet 2600n Printer
HP 2600n prints some blue vertical lines
Hello, our HP 2600n prints some blue vertical lines over the printed document. The lines goes from the beginning of the paper to the end and the pattern is not always the same but the lines are almost in the same position horizontally over the document.
If one opens the door of the printer, the black acetate has this lines too.
What could be happening?
Thank you very much for your answer and support.
  • Daniel Giraldo Jun 23, 2009
    Thanks for your answer, so I understand that it could be a problem with the black acetate. So the only way to fix it is changing that thing?
    Scholar:
  • 122 Answers
1 of 2 things: First, check yuor Cyan cartridge and make sure that it is not leaking. It may have a bad seal. If you replace it with a known good toner, the imaging unit (the black acetate thing) will need to be replaced. This is also a consumable unit.
Posted on Jun 23, 2009
  • Wiired
    Wiired Jun 23, 2009
    As I stated, you could just have a leaking toner, so i would try changing that out first. If it no onger leaking, the leftover cyan on the imaging drum will wear off in a few dozen pages. If it does not go away, thats when you replace the imaging drum.
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Hp 2600n line
after you have printed a few pages switch the machine off just as the paper leaves the fuser. then open the front cover and take a close look at the image transfer belt ( black plastic conveyor type belt)
use a torch shone accross the belt to better light the error- if you can see these Green/yellow/cyan lines on the belt then theres a good chance its coming from the toner units- ( also try print quality troubleshooting pages in the menus under diagnostics.look at the individual colour pages and look for any lines or Uneveness about the shaded colour) replace whichever toner is not printing correctly
Jan 22, 2014 | HP Color LaserJet 2600n Printer
I have not used my Hp Color Laser 2600N for several years nor less than 300 copies and now I am getting 2 vertical blue lines on my paper when I print
What you need to do is clean the print head because it is clogged with dried ink. A printer should be used at least once a week to prevent the ink from drying in the print head.
Hope this is of some help. Bud
Oct 14, 2009 | Computers & Internet
Vertical green line in papers
Your printer green cartridge drum cleaning blade is weak.you change it than solve it
May 30, 2009 | HP Color LaserJet 2600n Printer
A very thin light blue line appears on all printing jobs
Have you tried running some printer cleaning sheets through it? They are available through Office Depot, Fry's and other stores.
Also, it could be an issue with the imaging drum. I've worked on several printers which have had a similar issue and they needed the imaging drum replaced. Typically that helped.
Dec 09, 2008 | HP Color LaserJet 2600n Printer
RE: printing
you can change it on the fly as you print or
go to the start/settings/printers/ (then open your printer )
on the printer menu at the top ....
select printer /printer preferences and make the changes you want
Feb 03, 2008 | HP Color LaserJet 2600n Printer
HP laserjet 2600n
You are spilling blue toner. Try to vacuum out the excess blue toner from the machine. Be careful not to scratch the transfer belt.
Dec 13, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
1,864 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
