Question about Craftsman 25cc Gas Line Trimmer
Carb not working
I have a craftsman brushwacker model 636.796234,gas flows out of the carb,do i need a new carb and what is the part number,thanks
  • 11,896 Answers
Dont need new carb!!!! Just need to clean that one with solvent. the floats are sticking up allowing fuel to flow. Pull it off then pull it apart and clean it with solvent for an hour. Or spray and wipe it several times with carb cleaner.
Posted on Jun 23, 2009
Need operators manual to remove brushcutter blade
Hi mine has a hole behind the blade that you put a screwdriver in then turn the blade till it goes in to an aligning hole then it's screws off
Sep 27, 2017 | Craftsman Garden
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
I put a new carburetor on my craftsman model 358.795200 brushwacker; it idles ok but when i pull the throttle lever it stalls?
you will need to adjust the carburetor, I would use a 1/8 of a turn at a time, I am assuming the spark is new,also. Hope this helped Tim
May 22, 2011 | Garden
My briggs and stratton 675 lawn mower won't start. It has no choke or primer.
I am guessing that this is your ENGINE model number: 126K02-0512-B1
Using this reference:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=126K02-0512-B1&dn=35820003
Check to make sure that the choke item number 97 is not sticking.
Then remove the float bowl nut and float bowl assy. Clean the fuel passages in the base of the carb with carb cleaner including the area where the bowl nut screws into. There is a fixed jet orifice that must be cleaned in the threaded area. Also clean the visible brass tubes in the top of the carb.
Check fuel flow with the bowl removed. You should have a good fuel flow with the float angled down and as you lift it level fuel flow should STOP. If you do not have fuel flow... remove the float pin, drop the float and needle and celan out the hole where the float needle was. Remove the main fuel line and check for fuel flow. Use carb cleaner in the hole where the fuel line connects. If you do not have feul flow from the fuel tank.. check the tank port and look for any kind of in line filter. If you find a filter... check the line before and after the filter for fuel flow. Once you have established fuel flow Reassemble carb
Check the spark.... if you have no spark
First check the thermostat by just disconnecting it. Item 291
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=126K02-0512-B1&dn=35820004
Then retest your spark. If you have spark with the thermostat disconnected the themostat is bad. (Most engines use a low oil level sensor..... this one uses the thermostat)
There is an electrical contact on the throttle plate that is grounded when the throttle is selected to off. Make sure the throttle plate lever moves off of the contact when you advance the throttle. ALSO... there is another ground / contact on the engine brake. Make sure that when the engine brake is released that the brake lever moves away from the ignition grounding contact.
The above are the basics.... If after doing ALL of the above you still have problems with ignition then suspect the ignition components.
Thanks for choosing FixYa,
Kelly
Apr 27, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
When replacing purge bulb on my 32cc craftsman brushwacker I found 3 fuel lines off carb, two were connected to bulb, what's the third? I assume it goes to the other hole on the bottom of my fuel tank but...
the inlet line has the filter on the end in the tank
that goes to the bottom nlet of the carby
the return line goes from under the primer bulb back to the tank
some units run a 3rd line with a filter on the end ( outside of the tank0as that is used to vent the fuel tank as the cap is sealed
the fuel flow is this
through the carby through the pump back to the tank and is only used to prime the float bowl ( needle and seat and diaphragm with fresh fuel and to remove any air in that chamber
Aug 08, 2017 | Craftsman Garden
Mower backfires and loss of power
i would also check fuel flow. pull the gas line from the carb and see if gas flows out at a good rate (into a metal can of course) or if it trickles out. if the latter, then gas tank either has junk at the bottom preventing the gas from flowing or the vent hole (usually on the gas cap) is plugged.
i have also had my carb float bowl rust out on me, but that took 10 years.
Jan 21, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
42 inch Craftsman carburator not getting any gas. You can spray quick start and will will fire. Does gas from tank gravity feed to filter?
gas tank gravity feeds fuel to the carb. if you pull the fuel line from the carb, fuel should flow out of the tube. if it does not, then either the vent hole on the gas cap is plugged or there are contaminents at the bottom of the gas tank preventing fuel from flowing into the fuel line.
Dec 14, 2008 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 25cc Gas Line Trimmer Logo
425 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
