Question about Ricoh Office Equipment & Supplies
Where is the staple tray located in the Ricoh mp 5002?
4 Suggested Answers
  • 16 Answers
SOURCE: ricoh mp c3000 display error
make sure there is no paper at the back of the tray.also make sure the tray lift motor is working.the last thing to check is that there is nothig broking of the back of your paper tray..
Posted on Apr 30, 2009
  • 990 Answers
SOURCE: Will not staple
Hello sir; Remove the staple cartridge check there have left over used staplers , just dump it out,also need to check vertical lifting motor moving smoothly.
Posted on Jun 01, 2009
  • 114 Answers
SOURCE: I have a Ricoh Aficio 1035 stapler problem.
if you press the finishing button on the display does it so stapler function there ? or try taking the staple cartridge out and then close the door on the finisher and see if it says out of staples. if it does it knows it has a stapler unit.
Posted on Mar 17, 2010
Ricoh aficio MP C3002 where is the waste toner located
To the left of paper tray 1. Small door with one screw from the top. Open front door to remove screw from this small door. Close front door and open small door. Slide waste bottle out the front of machine.
Nov 07, 2017 | Ricoh Office Equipment & Supplies
I have a problem with my photocopier RICOH MP 5002 despite replacing new drum new cleaner blade and new developer my copier still copy very faint copies what could be the problem
when you replaced the developer, did you clean the "mag roll" of baked on toner? Very common problem on this model. Of course you initialized the SP mode 2-801, and 2-805 right? -Carl
Jul 29, 2016 | Ricoh Office Equipment & Supplies
Jams when duplexing on ricoh mp161
if you are talking the origanal in the DF check for staples or ppr clips inside the DF, or if it is jaming the copies try fresh ppr clean the rollers.
Apr 08, 2010 | Ricoh Aficio MP 161SPF Color Copier
Jan 20, 2010 | Ricoh Aficio 1035 Copier
THE DRIVE GEAR FOR THE PAPER TRAY IS BROKE
The gear drive is located in the paper tray lift motor assembly. The gears teeth strip away with wear and tear and can no longer lift the tray to feed paper. Replace this assembly and not just the gear.
Oct 14, 2009 | Ricoh Aficio MP 161 Black and White Copier
Will not staple
Jun 01, 2009 | Ricoh Aficio 450 Copier
How to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Nov 19, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
Ricoh mp c3000 display error code sc 502 on tray 2
May 02, 2008 | Ricoh Aficio 1018 Printer
223 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
