Question about Reliable Enviromate P7 Pronto Portable 4-bar Pressure Hand Held Steam Cleaner And Fabric Steamer Portable
How can I get the top off of turbosteamer 220?
The cap to the water reservoir is stuck
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    I have a turbosteamer 220 hand steamer. It heats up but won't spray steam
    It's most likely the trigger not engaging the piston that releases the steam. Due to the fact that the plastic inside the 220 holding the trigger in place has cracked on both sides.It will need to be taken apart.That's another issue.Be easy on the trigger press down gentle.....
    Jul 27, 2011 | Vacuums
    He filled the reservoir, turned on the switch and pressed the handle to get soap and water and nothing came out does not spray
    Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
    - Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
    - Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
    - Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
    - Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
    - Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
    - Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
    Nov 23, 2010 | Bissell 1699 ProHeat Clear View Upright...
    WATER WILL NOT COME OUT
    Nov 22, 2010 | Bissell 7901-R Clearview Proheat Plus...
    My bissell wont release water or cleaner
    Nov 05, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
    My bissell isnt putting down any solution or water
    Oct 28, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
    Steam buggy water reservoir cap has apparently been cross threaded, and cannot be removed by twisting or other "encouragement." If I cut it off, where can I get a replacement? Can the machine be used as...
    You need to completely annihilate the plastic cap by cutting it off and destroying the remaining plastic to expose the stainless steel insert/plug. You can use either a pipe wrench or 11mm wrench to turn the insert counter-clockwise to unscrew. You will need to use some force to get the plug out since it's basically glued shut by lime deposits in your tap water.
    Do not move the slotted cap or else this will need to be adjusted so that all your water doesn't squirt out before turning to steam.
    Next time only use distilled water. Store with the cap off. Grease the inner and outer threads after every use and wipe it off completely before use so it doesn't mix with the steam and turn to vapor.
    Sep 23, 2010 | Tristar SB Steam Buggy Vacuum
    I have Bissell 7920. The water is not being
    Jul 14, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
    Leaky reservoir tank
    For low suction, check that the flapper on top of the recovery tank hasn't lost its foam rubber gasket. If that's gone, you will get zero suction. If that's in place and the motor is running, you likely have a split in the hose. A service center can replace the hose or you can buy the hose and replace it yourself. For the leakage from the clean water tank, make sure that the cap isn't leaking. Fill the tank, apply the cap and then hold it in its normal cap-down position. If there is leakage, you can replace the for $3-$4 dollars. If there isn't any leakage, then the problem is inside your unit and a trip to the service center is in order.
    Jan 06, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
    Reliable Enviromate P7 Pronto Portable 4-bar Pressure Hand Held Steam Cleaner And Fabric Steamer Portable Logo
    43 people viewed this question
    Top Reliable Vacuums Experts
    JoeVacs
    Are you a Reliable Vacuum Expert? Answer questions, earn points and help others
