Question about Home
What is a fruit or vegi starting with x - Home
3 Suggested Answers
radar001
  • 1051 Answers
SOURCE: Purchased in 2002 and is starting to freeze in the
Check the back of the fruit and vegi drawers. If theres a slot for an intake port try closeing it (if adjustable) Check thermostat setting for fridge and adjust to a lower setting.
Finally make sure door closes and seals closed, clean gasket with mixture of white vinegar and water (1 cup vinegar to 1 gallon warm water). If this fails internal thermostat may need replacing.
Posted on Dec 17, 2009
  • 11 Answers
SOURCE: Don't know what number to
is the freezer working fine/ or is it too warm
Posted on Mar 31, 2011
Name food lizards eat
Fruits and vegies plus insects like crickets, worms & slugs. They are amnivores.
Oct 09, 2014 | Zoo Med Can O Mini Mealies 1.2 Oz Lizard...
We just purchased the Frigidaire FGHC2378LP and hooked up the water line and it worked, no problem. Then we unhooked the water supply from the water shut off valve for 3 days and hooked it back up and now...
Sounds like its frozen, is why you arent getting water unfortunately until you fix temp problem or unplug it to thaw it, its probably not going to work.
Sean
Mar 27, 2011 | Frigidaire FGHC2378L Side by Side...
My roper frig it has water inside under the vegie
clogged freezer drain in freezer. remove cover and work some hot water in and out of the drain with a turkey baster until water runs thru and then poutr more water thru drain until all ice is washed thru. good luck.
Jan 20, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Dec 17, 2009 | Amana ARS2464B Side by Side Refrigerator
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How to stop water from pooling on the middle of shelves. The water seems to come from nowhere. Also, what is the best setting for the humidity sliders on the fruit and vegetable drawers.
If it is a static appliance with a ventilator this can happen at colder settings you can try to increase the setting so the condensation can be decreased.That water is the condesed water which comes from your food.
Actually these has a very small impact if you do not have %100 sealed drawer.If you have fresh vegies it should be totatlly closed so the humidty levels increase in the drawer so the freshness.
Sep 26, 2009 | Maytag Refrigerators
I have a 2 tiered vegie steamer
you can do rice if its a boil in the bag type
Aug 20, 2009 | Kitchen Appliances - Others
Crisper and veggie bins are freezing the produce
I have dealt with bosch and thermador quit a bit and they usually don't have to much of a recommendation for these settings because they are more of a commercial type appliance producer and all situations are different. Here is a tip for the sliders though. Remember that leafy produce needs more airflow to hold its texture and taste and anything with a skin requires less airflow. As far as the temp settings I believe the most nominal settings are going to be in between 5 & 7 to keep from freezing the produce. You will have to play around with it a little though to get it to keep the ref good and cold but keep from freezing the vegies. Hope this helps. Good luck.
Jun 05, 2009 | Bosch KGU6655
Looking for downloadable juice extractor book
BOOK CALLED "JUICING FOR LIFE" AT AMAZON.
TRY 2 CARROTS, 1 APPLE, 2 CELERY STALKS
AND A HALF LEMON. ALSO IF JUICER BREAKS,
GO FOR SOMETHING BETTER LIKE AN ACME.
HAVE ONE SINCE 1990.
Nov 26, 2008 | Jack Lalanne KN2047 Juicer
Home Logo
297 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
