Question about Bissell 3576 CleanView II Bagless Upright Vacuum
How does the vacuum brush turn
How does the brush turn. I don't see how it turns unless it is fused together.
    New Friend:
  • 3 Answers
There is a belt that turns the brush.
Posted on Jun 10, 2014
  • 5 Answers
SOURCE: My vacuum wont turn on.
It sounds like you may have a faulty on/off switch. I suggest if you are not familiar with electricity please have someone that you know "is" to do the following. "UNPLUG" your vacuum and disconnect thee white wire coming out of the on/off switch. With a volt meter dial the meter to OHM's and hold one lead to the disconnected wire coming out of the switch and with thee other lead from the meter touch the metal housing of the motor. Click the on/off switch and if the numbers zero out your switch is good if the numbers on the meter stay the same chances are your on/off switch is bad. If the switch is good then the cost for a new motor is more than a new vacuum. Good luck
Posted on Aug 18, 2009
philschneide
  • 448 Answers
SOURCE: brushes won't turn
The brushes are usually driven by a belt that connects to one of the ends. They break. Check to see if yours has.
Posted on Oct 07, 2009
SOURCE: roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
Posted on Apr 03, 2010
SOURCE: when I turn on the rotating brush the vacuum makes...
ok, after long call with thech support I found it is bad bearings in the roller brush. So that needs replaced.
Posted on Jun 09, 2010
  • 147 Answers
SOURCE: No suction in upright vacuum.
it could be the filter or on this unit, one of the other 2 filters. The most common overlooked filter on this unit is the filter in the pull out tray under the bagless container. I would suspect that is the culprit cutting off your suction. Pull it out and wash the filter, wash the other 2 filters in your unit as well. Warm water and soap, little bit of bleach to kill the smell and LET THE FILTERS DRY BEFORE PUTTING THEM BACK INTO THE UNIT. I cannot stress that part enough.
Good luck!!
Posted on Jan 24, 2012
Ken more progressive upright vacuum
Stephen,
When you say that it will not turn, do you mean that it will not turn when the vacuum is turned on or just not turn when you try to turn it by hand. Did you make sure that the belt was in good condition before you put it back together? If you cannot turn the brush by hand with the vacuum off, then you might have an issue with the brush itself as well.
May 17, 2015 | Vacuums
Brushes not turning, 2 inch piec on one brush in place, the housing is spinning but not turning brushes
Hello there! It sounds like you may need to replace your brush block assembly. Try turning that drive shaft connected to the middle brush. All the brushes should be able to do a full turn simultaneously. If the brushes get stuck and cant make a full turn or if all of the brushes aren't spinning together then your brush block will need to be replaced. To purchase a replacement brush block simply follow the link below. Hope this was helpful!
Search Results
Sep 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Brush Bar wont turn
Once you put it back together recline the vacuum as normal use and turn it on. If not working still the brush motor is burnt up. Needing replaced.
Feb 16, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
The brushes are not working.
We have a Max Extract 60 and when we turned it on the brushes did not work. My husband took the pieces for the brush motor apart and put it back together and then they worked fine. They must of been bound up or put together wrong. Works great now.
Dec 21, 2010 | Hoover F6055-900 SteamVac Maxextract LS...
THE ROLLER BRUSH WILL NOT TURN. I PUT ON A NEW BELT AND IT BROKE IMMEDIATELY. THE ROD THAT HOLDS THE BELT IS MOVING BUT THE BRUSH IS NOT MOVING.
Apparently something is binding the brush, keeping it from turning. Remove any string, hair, etc., that is wrapped around the brush. Removing the brush is the easiest way to do this, then cut the material through at one point.
While the brush is out, check the ends for signs of damage that may cause the brush to bind. Also, check the area the brush connects to.
Reattach the brush and try to spin it. If it spins freely, put your vacuum back together, with another belt, and try again.
If this doesn't work, I suggest a new/different vacuum.
Oct 25, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Brush won't turn.
Is the grey "brush" button on the handle depressed? Brush won't turn unless the button is down
Feb 03, 2010 | Bissell 5770 Healthy Home Bagless Upright...
The motor for brush won't turn on for the bissell healthy home vacum
Jan 01, 2010 | Bissell 5770 Healthy Home Bagless Upright...
The rotary brush stopped spinning. I believe its
I have seen belts wear faster than that, believe it or not. Here is a link to the belt you need and a link to the manual:
Bissell Health Home Replacement Belt
Bissell Healthy User Guide (PDF)
Nov 17, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Brushes wont turn on shampooer
Dear Momneville
I have the same steamcleaner and had the same problem, I took mine apart a found a clog between the turbine and the wheel that the turbine moves by vacuum when it gets glogged there is no vacuum to move the wheel. If you are not mechanically inclined in suggest you do not take it apart unless you think you can get it back together properly.
Hope this helps
ahill_1
Dec 24, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Bissell 3576 CleanView II Bagless Upright Vacuum Logo
22 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
