Question about Avanti W757-1 21" Top-load Washing Machine
How can I fix the machines spin cycle, and what needs to be replaced?
The macine works fine except when reaching the spin cycle. It does not spin and leaves the clothes soaked. It drain water but does not spin. The clothes are left in a clump in the center of the machine tangled and very very wet.
4 Suggested Answers
  • 74 Answers
SOURCE: Re: machine can't drain the water.
Need a more info but lets see if the machine wash ok but dont go to the nex cicle you got a timer problem, the contacts of the timer could be dirt or worn out some times "ants" blocks the contact and just spray them with a contact clenear spray is the solution but be carefull disconect the machine from the ac outlet before work in that area if not then change the timer....good luck and rate me
Posted on Feb 17, 2008
SOURCE: does not spin.
hello in my washing machine, in my spinnig drum i have a plastic object that spins and can be taken off, it broke do u know a place were i can buy a new one or repair it
Posted on Jul 11, 2008
  • 190 Answers
SOURCE: My washing machine agaitates to wash the clothes but it does not spin to wring out the clothes at the end of the cycle it just stops
Dear Customer,
I recommend you to follow the below stated routines
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • And as for the clothes being wet after the spin..This may be a spin problem or a drain problem
    Drain:
    • Make sure the drain line is clear
    • Check the drain hose for a partial blockage
    • Inspect the water pump
    Spin:
    • Test the motor
    Please rate this Solution.. Thank You.. Good Luck..
    The agitator on this machine has stopped working though spin and rince cycles work fine. Will replacing the clutch solve this problem and are there any associated parts that should be replaced with the...
    if the spin and rinse cycles still work fine then i suspect it might actually be the gearbox which will need repairing/replacing. Be sure to get new seals when you remove the gearbox, unless the seals look in exceptionally good condition.
    Jun 26, 2011 | Washing Machines
    Fisher & Paykel Smart Drive 7.5 washing machine.
    Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
    Jan 07, 2010 | Fisher Paykel Eco IWL16
    Washer squeals during wash & rinse cycles.
    It sounds like you're brake stator & rotor is worn and merit replacement, it would also be prudent to replace the thrust bearing as well since you'll be in the same area for the repair. The way to verify is to place the unit in spin & allow it to reach speed then open the lid. If it squeals then the repair would need to performed, if it does not then further troubleshooting would be needed. Hope this helps... Bill
    May 29, 2009 | Maytag PAV2300 Top Load Washer
    The machine works fine until it reaches the rinse cycle.
    The buzzing sound is the cold water inlet valve is getting power but water is not able to enter. You need to have the valve replaced or make sure the cold water is turned on at the sink. Hope that helps, let me know.
    http://tclaundryrepair.com/
    Feb 28, 2009 | Kenmore 24032\24036 Top Load Washer
    Spin cycle not working
    Yes, the problem is fixed. With helpful online info and my husband, the problem was a coupler that needed to be replaced.
    Thanks again,
    Jill
    Jan 27, 2009 | Kenmore 24032\24036 Top Load Washer
    Tube doesn't spin during rinse/spin cycle.
    It needs a new clutch. Call a repair technician.
    Nov 19, 2017 | Washing Machines
    Washing machine making whining noise during spin only
    Yes, bearing, most definitely. It is a cheap part but difficult to replace.
    Apr 11, 2008 | Washing Machines
    Spin cycle is not working
    Macine will go through all the cycles then when it is time for it to spin it will just stop at 7 min left. I have replaced the control board and with no change. Any help would e much appreciated
    Apr 02, 2008 | Washing Machines
    Hoover 2305 washine machine wont spin
    Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
    Dec 29, 2007 | Washing Machines
    Avanti W757-1 21" Top-load Washing Machine Logo
    97 people viewed this question
    Top Avanti Washing Machines Experts
    Jim Thurston
    No_ky
    Kolbrun...
    Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
