Question about Bosch Washing Machines
Tyler, I have a Bosch Nexxt 500 series front load washing machine and when it gets to the spin cycle it will not drain. Also shows E04 code. There are not any obstructions any where in the drainage s
Bosch Nexxt 500 series WFMC3301UC/02 Tyler, I have a Bosch Nexxt 500 series front load washing machine and when it gets to the spin cycle it will not drain. Also shows E04 code. There are not any obstructions any where in the drainage system and the pump runs, however I am not sure it is running at full capacity. If I manually drain the water out then the machine it will spin. I unplugged the connector to the pump and with my Fluke meter I show 15.7 Ohms of resistance. Would you happen to know the the approximate reading for a good pump? Also what should the voltage be going to the pump with the selector in the drain position? Thanks
textonor
  • 130 Answers
SOURCE: bosch frontload washer will not drain
Hello Mamma5, It sounds like the drain pump is either seized or jammed. The drain pump has an anti jam device in it. Since you have figured out how to get into the drain pump, try turning the inpeller in the back. It will be a little hard to turn as the magnets in the motor will fight you on this. Look close in case there is anykind of thread wrapped around the inpeller. If so, then you can free the pump. If you cannot free it to run, advise the repairman what you found so he can bring a drain pump with him.
Hope this helps.
Posted on Jan 23, 2008
  • 1462 Answers
SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Posted on Oct 18, 2008
57 varieties
  • 1653 Answers
SOURCE: Bosch Nexxt 700 won't drain water
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
barkencoa
  • 3463 Answers
SOURCE: NEXXT Premium will not spin or drain
There should be a filter located at the bottom right front of washer behind drop down flap or plastic cover.
Unscrew anti-clockwise to remove and clean.
Posted on Jan 23, 2010
Testimonial: "Thanks. Great advice. We found a sock clogging the drain."
Code d:08 bosch nexxt series 500
It is bound to be a blockage or the impeller is stalling due to foriegn objects like coins.
Mar 06, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch nexx 500 washer led not coming on
Could be control panel issues or main board problem
Dec 08, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
It makes a squelling sound b-4 ging into the spin cycle. The clothes are not spun out very wet. This is the same without adding soap. I thought that was the problem so I rewash the clothes and the...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch nexxt 500. E04 message, checked drain area (round circle at bottom, checked ball valve, checked drain hoses, checked and cleaned container at the top right back of machine-where exterior discharge...
This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 01, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a bosch nexxt 300 series washing machine. The problem is it had beeped code E04 the hoses were somewhat dirty and i cleaned those,but now the pump doesnt seem to be running and its getting hot. ...
bosch nexxt 300 series washing machine This video will show you how to change the pump washing machine
Dec 31, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Sqeaks when spinning and washing - intermittently.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My bosch nexxt wont drain and flashes e04 checked imoeller and cant find any clogs impeller spins freeley
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Feb 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
The water won't drain from my Bosch Nexxt 500 Series Washer machine
I solved the problem by using a sump pump to drain most of the water, then I removed the cover plate on the lower front right of the machine to get access to the drain plug. Upon removing that, some water flowed out but not too much, I found a sock jammed in there which wasn't allowing the drain or spin cycle to work properly.
Interestingly, the machine's manual says that the cover plate is only to be removed by a Bosch authorized service repair representative. Saved about $150 by simply doing this myself.
Sep 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Dec 04, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
