Question about Panasonic PT-50LC13 50" Rear Projection HDTV
The television shuts off automatically
When the TV is turned on, it sounds like it is going to work and then it automatically powers off. Does this sound like a common problem with this type. It is a PT-51HX40B. The year it was manufactured was August 2000. I have a repairman coming to the house on 6-24-09. He said that he has did some research and read something about some type of caps? going bad. Any words of wisdom? I've had great luck with this tv without problems and would like to repair it if possible.
Thanks,
Tom
    Problem Solver:
  • 9 Answers
What he may be referring to is caps to stop the coolant from leaking on the curcuit board. One time I had to put a drip pan in my set to stop the overflow. Expect a $300-$450 bill.
Posted on Jun 24, 2009
What makes my tv shut off when turned on?
A short circuit or a loose solder point can cause this.
Mar 25, 2013 | Zenith Televison & Video
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
BIG SCREEN TV WILL NOT COME ON
YOU LOST VERTICAL DEFLECTION THIS IS NOT HARD TO SOLVE
Dec 25, 2009 | Televison & Video
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Power and sound turn off after 15 minutes
Is the red light blinking in the front of the tv. Counnt the blink sequence then I can give you more info.
Oct 05, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
MY TV turns off automatically after I turn it on
This sounds like you have a high voltage problem. When your unit turns on the high voltage builds up to the operating voltage. Apparently something is overloading the circuit which causes the set to shut down for safety reasons. This locks out the controls and you can't restart it until the power is removed which resets the micro. The unit is going to need professional help if you are not an electronics technician, and I'm guessing you aren't. This should not be a hard fix and the cost should be reasonable. Find a good repair shop and get an estimate or get it repaired. Good luck.
May 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
225 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
