Question about Moultrie D5 5MP IR Trail Camera
I set the time delay on my Moultrie D5 trail cam for 10 min. it takes a picture every 10 minutes when there is nothing present. Is there a sensitivity setting? or what is causing this and how do i correct the problem?
SOURCE: need to know how to operate, setup and use trail cam
I found a user's manual for the game cam online which helped me understand how to operate the camera.
Posted on Dec 04, 2009
  • 296 Answers
SOURCE: i have a moultrie 4.0 megapixel trail cam I have a
none. A # PRECEEDED BY E(event) is telling you the cam picked up, in this case, 756 events...not necessarily did it capture that many pics, but the sensor came on 756 times...had the critter stuck around past the delay setting, then you should have gotten a pic.
Posted on Feb 19, 2010
  • 296 Answers
SOURCE: moultrie D 4.0 continous exposures
..your not in "Interval Mode", are you?? IF your cam is set to start an "interval @ say 2400hrs( midnight) and to take pics every 1 min./5 min/;ect., IT WILL!
Make sure you're in "AUTO MODE"...It's easy to accidently hit the mode switch when moving the power switch from off to on..(I didn't find this out by reading a book...)
  • 296 Answers
SOURCE: Moultrie i60 game cam takes pics constantly while
If within warranty, with valid receipt.....send to Moultrie
  • 296 Answers
SOURCE: how to set the time and date
Looking at front (inside of outer door) the D-40 has very different look than my I-40s and 60s, but bet programming is near the same.
1st, turn red arrow switch to"setup";press select button until time/date appear,here, not sure of programing...pressing select at this point may take you out of time setup mode.Try the up/down buttons below the display once right time is displayed, press select.
Hope this works, and good luck.
Posted on Feb 20, 2010
My camera takes pictures and there.s nothing on them
Maybe they are being tripped by moths or other flying insects.
Jun 20, 2016 | Simmons 119236C WHITETAIL TRAIL CAMERA...
How do you get the m100 to take pictures by motion only?
Search Results
    [PDF]Instructions for M100 GameSpy Digital Camera - TrailCamPro
    www.trailcampro.com/manuals/2012/m-100.pdf
    THANK YOU for your purchase of the M100 GameSpy Digital Camera. Please ... The Mode Button selects the 3 modes of the camera - Camera Setup Photo Review or ...Accepts the Moultrie PowerPanel accessory (sold separately) only. ... Camera operates in Plot Cam mode during the day and Trail Cam Mode during.
    Moultrie Game Spy M-100 IR Mini 6.0 Megapixel Digital ...
    www.walmart.com/ip/Moultrie-Game-Spy-M-100/16386230
    Walmart
    Rating: 4.5 - ‎21 votes
    MOULTRIE Game Spy M-880 Low Glow Infrared Digital Mini Trail Game Camera ' 8 ....You can easily hold this mini IR camera in your palm. ... MFH-DGS-M100 .... Will ittake pictures only on motion detection? ... can get any size you want but don't forgetyou will have a lot of photos to delete. ... A. Will do video clips and stills.
Dec 25, 2015 | Moultrie Game Spy M100 Game Camera
Moultrie ac8
I do not have an answer, but do have the same camera with the same night time problem. I have just used it for the first time and all the night pictures are black. I assume the flash is not going off. I have a second one that I will test as well. Maybe some one knows something else but I find now way to toggle the flash off and on.
Jul 09, 2014 | Moultrie Video Cameras
Camera shuts down after 1-2mins an does not take pics
Just to let you I had Moultire m-80 when I used a pny sd card it ruined my camera. They were kind enough to replace it for me. I just use what they recommended do not have any more problems. I only delete pic on my computer and not digital camera. Try doing a hard reset take everything out turn to the on position for about 2-3 minutes after 3 min put brand new battery's in it while on the on position should say no card at this time. If doesn't turn camera off put sandisk sdhc card in it. Test camera again if still not working Moultire will help you I have talked them great customer service.
Nov 26, 2013 | Moultrie Game Spy M-880
My pictures at night are nothing but a black picture
HARD RESET TAKE OUT BATTERIES AND SD CARD, TURN IT TO THE ON POSITION FOR ABOUT 2-3 MINUTES WITH NOTHING IN IT. AFTER 2-3 MIN PUT BATTERIES BACK IN WHILE WITH THE ON POSITION IT SHOULD SAY NO CARD. ONCE IT SAYS THAT TURN OFF THE CAMERA PUT THE SD CARD BACK IN TURN THE CAMERA BACK ON AND TEST IN THE DARK. IF THAT DOESN'T WORK SEND IT IN FOR REPAIRS TO MOULTRIE.
Nov 07, 2013 | Moultrie Game Spy D-333 Game Camera
How to change the timing of pictures on the moultrie to not catch everything but deer.
In the setup, it has a function to delay time between pics...1 min. works best for game trails; 5 min. for feeders, ect. However, these cams are sensitive; blades of grass; a bird flying by; the tree it's mounted to swaying; heavy rain...should I continue?
Nov 08, 2009 | Moultrie MFH-DGS-100 Digital Camera
I have a moultrie 4.0 megapixel trail cam I have a error code: dly e 0756. what is the problem?
Sep 16, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie D 4.0 continous exposures
Feb 22, 2009 | Moultrie MFH-DGS-100 Digital Camera
Using Moultrie I-60 trail camera. We do not always get color pictures in daylight hours. Even though the info strip indicates sunny or partly sunny conditions, we often have only black and white...
THE I-40 & I-60 ARE KNOWN TO PRODUCE SOME B&W PICS DURING DAYLIGHT HOURS. ALSO THE DIRECTION CAMS ARE AIMED,I.E., FACING EAST, WEST WILL AFFECT TIME CAM SWITCHES TO IR MODE...
Oct 16, 2008 | Moultrie MFH-DGS-200 Digital Camera
Moultrie D5 5MP IR Trail Camera Logo
165 people viewed this question
Top Moultrie Video Cameras Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
