Question about Cuisinart Electric Pressure Cooker CPC600
Why does heat turn off on some receipts - Cuisinart Electric Pressure Cooker CPC600
XE-A207. Won't print while ringing up. But will when transaction over if you push receipt copy. It will print x/z readings
The receipt is turned off.
Turn key to OP/XZ mode. Press receipt button. Turn key back to REG mode.
May 13, 2017 | Retail Supplies
The times on receipts are incorrect resulting in problems with banking
Receipts only give you a indicator. This will vary a lot on different products. One thumb tule is lower heat, longer bake time. This will often give you a much better result.
Jun 09, 2015 | Miscellaneous
Print is fading from receit
Welcome to the real world. Fading receipt print is chronic. In this high-technology world, the only reason I can think of for using that fading, heat-produced print is to rip off the customer.
*No returns or warranty without receipt*. Months later you manage to find your receipt but it's so faded it's unreadable. A lot of good it does you but it sure helps out unscrupulous retailers.
There needs to be a law that receipts last ten years...
Apr 18, 2015 | Office Equipment & Supplies
How to program post receipt key to produce post finalization receipt on Casio TE2400 cash register? Thanks
As long as you have the receipt turned off using the receipt on/off button, you should be able issue one with the receipt button at the end of the sale. If you press the receipt button after the sale, what happens?
Nov 21, 2010 | Casio Parts Cash Register PC Desktop
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
Oct 27, 2009 | Sharp XE-A404 PC Desktop
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
function is in the “ON” status."
Sep 24, 2009 | Sharp XE-A404 PC Desktop
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
OFF.
All the best!
Greg
Aug 01, 2009 | Sharp XE-A404 PC Desktop
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
Brand new rowenta professional won't heat
The mostly problem in that case is the internal terminal from cord to iron is loose ,open it and fix the the terminal cord to iron,or go to the nearest shop to repair that.
Thanks & good day,
Edgz
Feb 12, 2008 | Rowenta DZ1700 Iron
Cuisinart Electric Pressure Cooker CPC600 Logo
49 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
