Question about Garden
My flymo is not working it is spluttering when starting I have changed the fuse
How to change blade on a flymo L470
there is a bolt that holds it on. just googled it
Jun 08, 2016 | Garden
HOW DO YOU CHANGE THE DRIVE BELT ON A FLYMO 360
Your question is in the video game consoles categories???
If you actually have a Flymo 360 lawnmower you will find a link below to the users manual. However I looked at the manual and it appears to be direct drive ie. no belt. http://www.flymo.com/ddoc/flyo/flyo2012_gben/flyo2012_gben__a505284803.pdf
Aug 16, 2014 | Video Game Consoles & Games
Flymo instruction manuals
www.flymo.com/uk/robotic-lawnmower-support
www.flymo.com/uk/contact-us
Jul 14, 2014 | Garden
Flymo RE320 non working consistently, possibly due to rain? Any ideas?
If it runs ok with no sparks etc when you press the switch now and again i would think there is a problem with the switch itself, change the switch.
Aug 31, 2012 | Garden
How to change the brushes on the motor in a flymo 340 compact
There are no brushes available for this model, if the brushes are worn that bad the motor will be just about worn out as well, new motors are available.
Jul 21, 2012 | Electric Garden
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
Hi, i just swapped my elec flymo for a briggs and stratton 35 lawn mower, however when ever i start it it coughs and splutters and wont run for more then 30 secs and is also spitting out oil from exhaust....
if the motor has been on its side the oil has runs out thru the muffler and air filter. briggs are famous for doing that. let it sit overnight and remove the air cleaner and you see is fill of oil. next day take the spark plug and clean it and check the gap then put it back, take carburator cleaner and spray some inside the carburator, check the oil level and start.if it wont start then is time to clean carburator. the air filter if is wet in oil and is the dry type. get a new one.
Feb 08, 2011 | Briggs & Stratton Garden
No power when switched on.
sounds like the engine isnt getting the power to turn it sorry but flymo mowewrs are a pain to repair as they some times cost more to do than buy a new one
Jul 10, 2010 | Garden
Splutter Problem
iNCORRECT PLUG GAP
Feb 09, 2009 | 1998 Aprilia RS 250
Xsport 110 pit bike
check the 4 stroke oil if it starts to splutter at half throttle
Nov 08, 2008 | Cycling
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
