SanDisk Sansa m240 MP3 Player Logo
Posted on Jun 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Installing mp3 playing on computer
When I tried to install the mp3 on my computer it told me the drivers for the device are not installed model Sansa SanDisk m240
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Jun 23, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3734581
Points
36074
You can download the drivers from sansa, downlaod.com, and many other sites carry them. They will need to be installed for pc to recognize the player
Cannot find driver for sansa sandisk 4 gb e260
Hi cream_soda21,
There are no drivers needed to be installed because Sansa Sandisk is a plug and play device. However, if your device can't be recognized by the computer, please consider visiting the link below. Please follow the step by steps procedure.
Sansa player not recognized by the computer
Hope it helps.
Thank you for using FixYa.
2answers
Computer says problem with new hardware when plugging in Sansa Clip MP3 player
Go to this link and select your unit in the download wizard and download the drivers for your device. Install the drivers without the Clip MP3 plugged in. Once the drivers are installed, you can then plug in the Clip MP3 and windows should correctly identify your new hardward and finish installing the drivers for it.
1helpful
How do i erase all the music stored on this mp3 (model e250)
if u have a installer CD with the device then
please install the driver then plug your device
in the connectivity cable.
format your device memory in my computer
1helpful
Is there driver/ software for Win ME for the Sansa Clip mp3?
a friend told me that if the device shows as"connected" when hooked up (it does) AND the battery charges correctly (it does), then (a)the USB connection had enough juice; and (b) the PC recognizes it - i just had to FIND it. device manager/ MyComputer: nada; same for ANY file/ folder with "sansa" or "sandisk." working thru WMP (Windows Media Player), however, I discovered that drive E - for a portable hard drive, NOT currently connected via USB - was STILL showing up in the "Copy to CD or device" field. sure enough, it was the SanDisk clip player (even though it was NOT under the "Recognized Portable Devices" subsection). without using the installation disk at all, it downloaded tunes just fine. *note: the installation disk seemed to be an .exe file ONLY for the Rhapsody music service. as noted above, it was unnecessary. also - my USB ports are 1.1 and not 2.0, and package stated USB 2.0 was a "minimum requirement" - not true*
SanDisk Sansa c240 1gb driver problem for vista
try using sansa media converter you need quicktime player for it to work
E250 doesn't connect computer
what you will need to o is to install the vista driver..Once you have the driver install the device should be working without any problems..
Follow the link below to obtain the driver for your device..Select your device model and operating system.....
http://www.sandisk.com/DriverDownload/index.asp
Thank you
Computerrep
Device driver m240
Uninstall all Sansa software using the add/remove programs function. Reinstall software from Sansa CD. Then and only then plug the mp3 player into the computer.
Sandisk m230 sansa, has no power
your going to need the driver install disk you can buy it at a kmart or wallmart they go for about $50 the only way you can get a driver back ~SP1Grim
3answers
My Mp3 player does not plug and play properly in my Xp computer
Youmust have instaled MEDIA PLAYER 10 , oderwise your computer will NOT see the device
2answers
Computer not recognizing my Sansa m230
try updating the driver: right click "my computer" > properties > hardware (tab) > device manager > and you'd have a large list of hardwares. go to portable device, and click "sansa m2xx" (or whatever it is that says in your drive) to highlight it, and click the "update driver" button, which should be the 3rd to the last button at the top of your window. that's how it worked for me, and i'm using windows xp version. hope this helps.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
