Question about Dryers
Schematics of HTDX100EM2WW
How to wire dryer timer?
3 Suggested Answers
Fix-Fox
  • 7 Answers
SOURCE: schematic / wiring diagram for Whirlpool Dryer timer motor M460-G
Here you go:
http://www.imesa.it/areatecnica/INDICE%202009/ASKO/SERVICE%20MANUAL%20PES%2010.pdf
Posted on Jun 17, 2010
Fix-Fox
  • 7 Answers
Here you go again :-)
My Daughter has a hotpoint experience tumble dryer and has removed the wireing off the back of the timer and doesnt know which one goes were can any body please help its a hotpiont experience TVEM70C6
Hello Adrian;
My name is Peter. I am a retired field service appliance technician.
Below is a picture of your timer switch. Also is a video of how to replace the timer switch. You must play and stop the video watching where each color or combination of colors go to each terminal. Orientate your timer in the same position the person in the video is holding the new timer.
It you purchased a new timer switch there will be a wiring schematic in the box. The schematic may be difficult to read.
A new timer will cost $65.00-$85.00 USD
Good Luck,
Peter, Baltimore, Maryland, USA
Nov 13, 2014 | Dryers
The dryer buzzer keeps going off even when dryer is off
When the dryer stops can you advance the timer a little to turn off buzzer? Or when you open the door does the buzzer stop? I was trying to find a schematic for that model but I have had no luck. Power should come from the timer to the buzzer. If you know how to read a schematic. Unplug the unit and remove the back to the control panel. Check to make sure that all the wires to the timer are on the right connections. You may need an appliance repair service from your area to come out and diagnose it for you.
Apr 02, 2013 | Frigidaire Westinghouse Electrolux...
Kenmore model number 41784052500 runs but will not heat. had repairman check thermostat and heating element couldn't find any thing wrong.
did he check the timer? If the machine isn't getting a command to go into the start mode, that could be your problem ,, However Label the wires connecting to your timer motor so that you will be able to correctly reconnect them later. Carefully remove the wires. Do not pull on the wire itself. Instead, use needle nose pliers to pull gently on the wire connector.
Set your ohmmeter to the R x 1 setting. Take each probe and touch it to one wire. A normal reading for most dryers is in the 2000 to 3000 ohms range. Try to locate a schematic for your dryer. It should be in one of the service areas of your dryer or in the owner's manual. This schematic should indicate the proper resistance reading for your specific timer motor.
Jul 15, 2011 | Kenmore 63942 Dryer
Bought new timer for Prodigy but thought i set the wires from the old timer in proper sequence but doesnt work so maybe wrong wires on wrong terminals
Look at the wires. They have markings on them that match the markings on the timer. Did you check the Non-resetable limit? If it is open the dryer will not run.89819b0.jpg
More here
Jun 06, 2010 | GE DVL223EBWW Electric Dryer
Timer
I have seen a similar question before. Look up the wire schematics and see what that wire is for. The sire schematics usually come with the dryer.
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
Frigidaire electric dryer feq1442eso melted bracket new bracket doesn't have the same colored wires. Need schematic for wiring.
There should be a schematic inside of the back panel or inside the control panel(where timer is)
Feb 22, 2010 | Dryers
Looking for dryer diagram
There should be a schematic on the inside of the back cover, sometimes it is located in the top control panel somewhere(timer panel)
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
