Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
Mx3200 clock re setting
Can you tell me how to reset the digital clock.
thanks
Frank
  • 26 more comments
  • bayliner Nov 04, 2007
    Thanks for trying but it did not work has anybody else any idea how to re set the clock on the mx3200 keyboard.
    Frank
  • winggo Nov 05, 2007
    how do you change time and date
  • Tyrel Nov 12, 2007
    That works perfectly. If this answer somehow doesn't work for you, either you don't actually have an MX3200 or your keyboard is defective. You can check the Setpoint software if you like, but FN + F10 should definitely allow you to set the clock.
  • Anonymous Nov 14, 2007
    Setting the clock.
  • Anonymous Nov 20, 2007
    set time
  • heatherl327 Nov 26, 2007
    how do i change the time on my logitch mx 3200 keyboard
  • Anonymous Dec 15, 2007
    Cant set clock on my new Loditech keyboard
  • Anonymous Dec 17, 2007
    How do i reset the clock!
  • Anonymous Jan 25, 2008
    How do I set the clock and date on the Logitech Cordless MX 3200 Keyboard?
  • Anonymous Feb 22, 2008
    How can this happen? Instructions don't show how to do this and neither does this site. All I want to do is set the clock and date. How hard can that be to answer? Push the F10 with Function and push the Mode key, no way to advance the settings. How do you do it?
  • Anonymous Mar 08, 2008
    how to set clock
  • goofyball Mar 08, 2008
    how do i set the clock on the MX 3200 Logitech keyboard? Instructions are poor.
  • Anonymous Mar 09, 2008
    what the **** just tell me where to go to get help setting a ****in' clock ******
  • drewpat Mar 21, 2008
    how do i change the clock ?
    how to change the LCD clock - lost instructions
  • Anonymous Mar 30, 2008
    how to change time and date on Logitech wireless keyboard
  • machinemann Mar 31, 2008
    how do i set time and date on mx3200
  • Anonymous May 04, 2008
    logitech cordless desktop mx 3200 laser
  • kitten53538 May 13, 2008
    i don't know how to set the time and date on the mx3200 keyboard. can someone help me?
  • Anonymous Jul 01, 2008
    yeay the website worked! basically it's the fn and f10 together. (The fn key is between alt and control under the right shift!
  • Anonymous Jul 13, 2008
    I have no idea how to set the date and time.. no insturctions..
  • Anonymous Sep 15, 2008
    How do I reset the clock and time on the keyboard?
  • Hepzibuh Nov 03, 2008
    Thank you! This was the first site I came to after I Googled the problem this morning. It saved me a lot of time. . .get it . . .time?
  • Anonymous Dec 31, 2008
    how do you change the time?
  • mfbaird Mar 09, 2009
    FN + F10 doesn't work. The colon is blinking on the clock but won't change with the up and down arrows or the number pad
  • templenc1 Apr 02, 2009
    I need to set up my clock on my Logitech MX 3200 keyboard. Help...
  • g_grandma31 Apr 04, 2009
    I need instructions on re-setting the digital clock on my mx3200 wireless keyboard.
  • Anonymous Apr 13, 2009
    How do I set the clock on the keyboard?
Hold down FN and F10 which says set in blue. This allows you to reset the clock.
Posted on Nov 04, 2007
Press F10(set) and fuction (FN) key at the same time once you do that look at the clock on the keyboard it should be blinking to change the time you use up and down arrows. To chage the minutes press F10 and FN again this is to change the date and time and if you want 12hr or 24hr. Hope this works good luck
Posted on Feb 24, 2008
  • 39 Answers
Hold FN + press F10 worked for me. Then just use the arrow keys to change the settings. Up/Down to set, Left/Right to change the parameter.
Posted on May 29, 2009
Push FN and F10 buttons at the same time. This puts you in the set mode then just type in the numbers or use the arrow keys--- pushing enter after each entry.
Posted on Dec 17, 2008
Thanks for the info. that worked fine.
Posted on Nov 28, 2007
FN + F10
Arrows up and down
F10 öfr min, 24h and date
ENTER
Posted on Jan 09, 2010
Use the F9 thru F12 keys while holding the blue "FN" key. Go from there.
Posted on Nov 03, 2008
    Problem Solver:
  • 14 Answers
Press and hold the FN key. Now press the F10 key while holding down the FN key until the first digit in the time starts blinking - use UP and DOWN arrows to change times, etc. Press F10 to go to the next number to be changed. Repeat until finished.
Posted on Nov 03, 2010
Thanks the solution helps me alot!!
Posted on Apr 25, 2008
Very helpfull Thank you :0)
Posted on Apr 04, 2008
Thank you for the info.! Works great!
Posted on Mar 05, 2008
The problem on how to change time on my logitech mx 3200 is fixed . Thank's for all the help, fn & f10 worked just fine. winggo
Yes function button down by the alt button and f10 pressed at the same time allowed me to change my time date thanks everyone
Posted on Apr 27, 2010
  • neo0o0o Apr 27, 2010
    worked good for me to thanks....
Thank you it worked for me. Tab moves through time and date sequence.
Posted on Oct 26, 2008
Why does nikon j1 clock reset each time the camera starts up
Yes, there is a separate battery for the clock and all of your saved settings that is not user replaceable. All Nikon 1 cameras are still in warranty because the camera only recently became available. I would phone Nikon USA's Service Department at (800) 645-6687 Monday through Friday from 7:00 a.m. to 8:00 p.m. and they will tell you how to proceed.
Jun 28, 2014 | Nikon 1 J1 Digital Camera
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
Mar 02, 2011 | JVC Audio Players & Recorders
Keyboard clock
1. press the "fn" key (just below the question mark key) + F10
2. press F10 to step thru hour, minute, month, and day
3. press F10 to exit setup
or go to logitech web site and view the ms3200 manual (a pdf of the instruction sheet that came in the original package).
May 04, 2009 | Logitech Cordless Desktop MX3200 Laser...
How do i set the clock on my mx 3200 keyboard?
To set the clock and date all you nee to do is have it on the clock and date mode. If you have it on a different mode hold the function (FN) key and press mode (F9) to toggle through each of the modes until you get to the one you want.
Then, to set it hold the function (FN) key and press set (F10). Next type in the numbers that you need for the hour time, then the min, then select 12hr clock or 24 hour clock with arrows, then select the month with the arrows, and finally select the day with the arrows. pressing enter to get to each step respectively. don't forget to rate me
Feb 02, 2009 | Logitech Cordless Desktop MX3200 Laser...
MX3200 Cordless Keyboard alarm clock
Hold down the FN button (next to the right CTRL button) and press the F11 button.
Jan 31, 2009 | Logitech Cordless Desktop MX3200...
I have a mx3200 cordless keyboard that has a clock and date window. The alarm clock goes off at 2:00pm how do i turn it off? Do you have a manual I can download?
got this off the logitech forum, The only instructions that I can find (which came with my relatively new pc) are on a large "Installation Guide," the most pertinent information from which is about setting the time and date: "To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Dont lite up at all cant even see clock
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Jan 04, 2009 | Logitech Cordless Desktop MX3200 Laser...
Clock reset
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 07, 2008 | Logitech Cordless Desktop MX3200 Laser...
Set time and date
You have to be in the 12 hour mode to correct this issue
Jun 06, 2008 | Logitech Cordless Desktop MX3200 Laser...
Keyboard
Go to
this page on the Logitech support site
and follow the seven steps to adjust the LCD time and date on your Logitech MX3200 keyboard.
Don't forget to rate this solution once you've tried it !
Apr 28, 2008 | Logitech Cordless Desktop MX3200...
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
10,733 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
