Question about Lenovo IdeaPad Computers & Internet
Loose charger port how do i fix?
Always been loose...now so loose it will not charge!
    Champion:
  • 207 Answers
The jack is broken, and the laptop will need to be serviced. If you have never repaired Laptops, it is a good idea to let a skilled person do the repair work, as there are quite a few steps involved including soldering the wires to the new jack.
Posted on Jul 13, 2015
5 Suggested Answers
bogolino
  • 8 Answers
SOURCE: The charger port on the computer is loose how do i open the port
unfortunately you will have to open up the notebook, take out the hdd, optical drive, wlan card, ram card(s), motherboard, and under the mb, there will be your charger port. Recomandation: Don't try to fix it yourself, UNLESS you know what you are doing. If you don't just go to the local repair shop.
Posted on May 06, 2010
Ezrahite
  • 2632 Answers
SOURCE: Hp dv5 charger port seems to have u loose
You need to diagnose first if the problem is the charger or the port of the laptop itself if it is possible to try a different charger to check if the cause of the problem is the charger if not then what i suggest is for you to check if you still have a warranty for your HP laptop so that you can bring it to the repair center free of cost because it might be the motherboard that it is causing the problem
Posted on Aug 01, 2010
  • 2567 Answers
SOURCE: the charging port on my
Please refer to the following article for a detailed diagnosis & fix:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Posted on Dec 14, 2010
  • 155 Answers
SOURCE: hp g60 laptop needs a charger port replacement
I had the same issue with a toshiba. I opened up the laptop and put a cut piece of wood that fit behind the connection. that prevented it from falling out when the charger was connected. tape will help hold things in place.
Posted on Mar 10, 2013
My daughters tabeo charging port is loose and wont charge how do i fix it?
I would take it to a tech. before it gets more damage
Dec 17, 2014 | Toys R Us Tabeo
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jun 18, 2014 | Samsung Galaxy S 4G Cell Phone
Googe nexus 7 will nt charge
If you feel comfortable you could take it apart and re-solder the charge port. Most tablets are not that hard to take apart. You really just need some plastic pry bars and small screw drivers
Nov 20, 2013 | ASUS 32GB Google Nexus 7" Tablet with...
My phone wont charge i always have to put it in a different position too get it too charge wats wrong with it?
Hi, there are two things you will need to test for ,
The charger and the charging port.
The charger of the phone might not be contacting properly causes it to fail or loose contact, that might be the reason it needs to be position properly before it charges.
You can use another charger to see how firm it will on another phone, so that you can be able to know if you will need to replace the charger with another one.
The charger port is where you plug in the charger to the phone for the phone to be able to charge.
Sometimes if the charging port is weak,itmight not be able to hold the charger properly,it will be failing contact.
Also you can use another charger to test with your phone and see how firm it holds on the phone and if it will charge the phone without failing.
I guess when you test for the charger and the charging port, problem will be solved.
Feel free to pass your comment.
Thanks for using fixya....
Jan 11, 2011 | Sanyo Cell Phones
When I try to use my car charger for my sciphone, after about 45 seconds it always says "Warning, Bad Contact Charger!" What does this mean and how do I fix it???
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 15, 2010 | Dual Electronics CECT P168 Cellular Phone
My nokia N97 just doesnt charge please HELP!
The problem is very clear, since you said you no matter the charger you use.
The problem with your phone is the charging port, the charging port of your phone is bad and will need to be replaced.
Replace the charging port and your phone will charge.
Take care.
Apr 20, 2010 | Cell Phones
Phone is in the charger and after charging for a little bit it stops charging and says "warning bad contact of charger" how do I fix this problem for nokia n97. Please help
Hi, the problem is with either the phone charger or the charging port IC.. First of all, change your charger and see if the problem will still repeat itself, if it does, then you have to take the phone to a phone technician to change the charging IC.....
Feb 25, 2010 | Nokia N97 Cell Phone
Wont chrge
i think there is some problem in the charging port just open the handset(if you are good in opening) check whether is there any loose contact near by the charger port .....
if so just remove it and readjust it again ...
this solves your problem ...
if you are not good in opening the handset then just visit the technician ....
it is just a matter of some bucks....
& also try charging with other charger ... there may be some problem in charger..
any doubts reply me
i am always here to assist you
thank you
bye
Jul 24, 2008 | Cell Phones
No charging and inside sim card
any doubts reply me
thank you
bye
Jul 04, 2008 | Nokia 1110 Cellular Phone
Not charging N1100
i think the charging port might have damaged or the charging IC is gone ...
just give a try with the other charger ...
if the charging port is gone then you replace the port with the new one ...
if the charging IC is gone you must get the new one and solder it ....
just have a check after opening the handset check whether is there any loose contact inside near the charging port ...
make sure of which type of problem you have and then taking the necessary steps ..
any doubts reply me
thank you
bye ....
Apr 10, 2008 | Nokia 1100
Computers & Internet Logo
41 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
