Question about Sharp EL1750V Scientific Calculator
Getting e code in left corner - Sharp EL1750V Scientific Calculator
Keep on getting the code 1080i at the right hand side top corner.
Hisense FAQs
www.hisense-usa.com/support/faq.asp
Hisense... Wine Cabinets. Laundry. Washers. Frequently Asked Questions Get answers to the most common questions. ...... Universal Remote Codes. Universal Remote.Missing: hand
[PDF]Hisense Roku TV User Manual
hisense-usa.com/support/manuals/40H4C_us_M_en_man.pdf
Hisense(black bars at top and bottom of screen); or viewing normal style (4:3) media on a widescreen (16:9) display (black bars on left and right sides of screen). ix ...Missing: 1080i
I have some informational text in the top-left corner... [META ...
https://www.reddit.com/.../i_have_some_informational_text_in_th...
RedditDec 25, 2014 - /r/Cordcutting - Cutting the cord, but keeping it legal. ... I have some informational text in the top-left corner. ... saw this problem on my moms roku. didnt know how to get rid of it. came ... Clicking the right stick will toggle that display on and off if that .... 06:26:06.164191+00:00 running cb0da57 country code: US.Missing: 1080i
What router settings do I need to set up Chromecast? - Google ...
productforums.google.com/d/topic/chromecast/ZGm4p8VcpAU
Google
Jan 05, 2016 | Hisense Televison & Video
Just came up with this Error code E000019-0002
Error code E000019-0000 is a waste toner full error
To get rid of this error you remove the waste toner bottle which is located on the left rear side of the machine
Dispose the waste toner and dont forget to clean the neck of the bottle because the waste toner might obstruct the toner sensor passage and then switch the printer off then on and you are up and running.
Just in case you have problems finding the waste toner
It is on the left lower corner just left off the big door that opens up.There is a screw in the upper right corner of the cover it is about 4 inches wide and 7 inches tall. You have to open the door for the fuser to get it out.
Make sure you clean out the toner completely.
Thanks,
HP Printer Support
May 22, 2014 | Canon ImageRunner 4570 | IR4570 |
For got pin code
You will need to get into maintenance mode and "clear user data". Do this by touching the lower-left corner of the screen while turning on your Nuvi. Keep your finger in that corner until you are prompted to go into "Maintenance Mode". Choose "Yes" and once in the menu, choose "Clear User Data". After that, exit and reboot the unit. If the lower-left corner doesn't work, try each of the other three remaining corners until you get the right one.
Note: Any user-stored and configured data will be lost as the system is restored back into factory mode. However, it should be noted that this will not affect any upgraded map files.
Jan 25, 2011 | Garmin Nuvi 370 Car GPS Receiver
Region free Samsung Blue Ray player BDC5500
this is already a regional (plays all 6) free (at least this model is suppose to) player.
you can also update your players firmware from the link below.
  • http://www.samsung.com/us/function/search/espsearchResult.do?keywords=Samsung+BDC5500+Player&input_keyword=Samsung+BDC5500+Player
Jul 26, 2010 | Samsung BDC5500 Player
When driving my 04 ram 1500 (5.7 liter) on the highway at about 65 or better the check engine light comes on and then i get the flashing lightning bolt in the left hand corner? ive been reading forums and...
I do not know what the flashing lightning bolt on the left hand corner means, except that reminds me of electrical, but couldn't find a reference to it in my research.
If you have a check engine light, then it probably left a code recorded behind. I would start there.
Ask to have the computer scanned for codes, and this may point in the right direction.
Good luck.
Jun 22, 2010 | 2004 Dodge Ram 1500
Crack the code on my blu ray to play all zones
I cannot vouch for this actually working but it is listed as
* turn on dvd player
* make sure there's no dvd in closed tray
* press 'repeat' button
* 'no disc' disappears in left corner
* press 29334 if you have a R1 player
57538 if you have a R2 player
56732 if you have a R3 player
76884 if you have a R4 player
53814 if you have a R5 player
24462 if you have a R6 player
* current region code is visible in left corner
* press 9 for code free
* press 'Standby
Sep 29, 2009 | Samsung BD-P1400 Blu-Ray Player
Break desktop code
if earlier you do not changed your bydefault code then put 12345 as your code.
thanks...........
Rgrds: Rajiv kumar 09811461147
Mar 28, 2009 | Nokia 1208 Cellular Phone
Hi i bought a SAMSUNG DVDF1080 and it will only play PAL dvds do you have an unlock code? cant find one that works. thanks
1.- Without any disc in the tray turn on your player
2.- Wait until the sign “no disc” shows up in the left up corner of the screen
3.- Press “info” button in the remote (“no disc” should disappear from the left up corner)
4.- Press in the remote the code corresponding to your region
R1 - 29334
R2 - 38767 or 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 – 24462
5.- The number of your region should appear in the left up corner of your screen
6.- Press the button “9” in the remote
7.- Press the button “repeat” (is under the number 6) in the remote
8.- Turn off your dvd player,
Sep 20, 2008 | Televison & Video
Saeco Primea Ring - no milk - just steam
Hello!!
Okay! Looks like many of you out there has the same problem, whit the milk temerature (not me i never had).
But there is a service menu on primea touch plus series.
Im from Sweden but i will try my best to explain how to enter the menu. First of all !!MUST!! write down off parameters before changing any thing!!!! It is possible to set the grinder to grin more coffie for each cup. I think the factory setting is 85 Aroma impulse. It is possible to change that for you type of coffie beans that you use, i will diff from bean to bean.
Okay, to enter the menus you have to turn you machines off.
Now turn it on !!!!!EXACTLY!!!!! when the display lights up press your display in the following order ALWAYS IN THE CORNERS (you will not see any icons were you have to touch on you display) RIGHT LOWER CORNER, LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER.
To enter the second service menu, do as i explained before but use this "CODE" instead. LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER, RIGHT LOWER CORNER. This is it! Hope i could help you! Remeber to write down before doing any changes! DO NOT ERASE ANY FAULT CODES YOU SERVICE CENTER WILL FIND THAT INFORMATION VERY IMPORTANT!!!!!
Dont say that it didnt work, it will it´s a huge matter of timing!!!! IT WILL WORK!!!!
Let me know some results please!!
Apr 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
1 RED LIGHT BOTTOM LEFT CORNER
This usually means something is wrong with the graphics scaler. You'll eventually have to send your xbox in to have it fixed, and I believe it is covered under a one year warrenty.
Feb 26, 2008 | Microsoft Xbox 360 Console
Sharp EL1750V Scientific Calculator Logo
55 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
