Question about Craftsman Lawn Mower
How to sharpen blades on manual lawn mower
Mower difficult to push and doesn't cut well
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
  • 376 Answers
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Posted on May 25, 2009
  • 24 Answers
SOURCE: i have a craftsman lawn mower that when i engage
I would check the stindles on the deck to see if they rotate freeley. If so.. check on the deck to see if the meckanisim for the brakes for the pullys is still engaged.
Posted on Aug 15, 2009
  • 110 Answers
SOURCE: I need to find mounting bolts, blade to shaft
Do you meanengine mounting bolts, blade boss, and 'Operator Presence Control' cable? If so, they are generic parts - not specific to your mower. I have no idea why you are having problems ordering them - they are consumable parts, and should be stock items for ant garden machinery repair outlet.
Posted on Sep 24, 2009
SOURCE: duel blades on craftsman riding mower cut unevenly
Its not the tires it is the blades don't line up.One blade is three-quarters of an inch lower.Is there a shim for the star fitting.
Posted on Jun 11, 2010
Polan selfpropeled mower the blade is not spinning fast enough and hardly cuts the grass
Blade speed equals engine speed. Check your carburetor and fuel pipe
Make sure you sharpen the blade with - this is more important for a good cut.
Mar 19, 2014 | Garden
Mowers flattens not cuts grass. whereisit and how do you correctly adsjust base plate
Your problem seems to be with your blade. If you are able to sharpen it yourself then do this .It will cut the grass as if a knife would cut a steak. Your blade is apparently very dull. If your not able to do this for yourself, than take it down to your local mower repair shop. They will sharpen for you. GOOD LUCK.
Jun 25, 2011 | Garden
How do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
Nov 12, 2009 | Garden
Lawnmower blade turns but does not cut
You have either bent the blade and its to high to cut or you need to sharpen the blade with a grinder.
Aug 01, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blade not engaging
The blade will spin automatically when the motor runs because it is connected to the main shaft. If it is not cutting, it will have to be removed and sharpened with a grinding wheel
Jul 03, 2009 | Toro Lawn Mower With Toro Power Tools
Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Having a hard time to fill the bag and almost not cutting grass
Well it could be your blade on the mower, over the years i have had to profect my blade sharpening skills.
sometimes when a blade is shapened its not done correctly causeing a lack in the blade tossing the grass properly and more or less turning into mulch on the lawn.
You should have your blades on a push mower if used once a week through out the season sharpened once a season then
if you have large amounts of rocks, sticks and pinecombs then 2x a year
if you only use it here and there then ushally ever 2 years is good.
another issue could be the engine bogging down when going over heavy or wet grass. this is no fun..
what I do with my lawn mower is clean the bottom and spray it with PAM cooking spray has been far the best solution, spraying the bottom of the deck and blade.
Now saying that if you try this method then remember no wet grass so dont over water your lawn.
some people like to use POR 15 on the under side of their mowers as well but I havent tryed this yet but hear it works great.
so there is ways to prevent slow and no discharge into the grass catcher.
hope this helps but yes I would say clean the underside of your mower and have you blade sharpened by a professional. dosent cost much and so much more worth it.
Aug 14, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Craftsman Lawn Mower Logo
23 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
