Question about Garden
My snapper rideing mower sr1030 will not start changed plug and checked safety switches
2 Suggested Answers
bbreton
  • 437 Answers
SOURCE: Snapper Hi-Vac riding mower that won't start with starter
You may need a 300cca battery, an ignition switch or a solenoid to get things going again. I also would check to make sure the starter gear has not locked in the flywheel teeth; it will burn up the starter. You should be able to go to the snapper website and put your model of mower in and find the parts and diagrams you need.
Good Day.
Posted on Oct 26, 2009
My Snapper NXT2346 just stopped while mowing checked battery is ok, no power to starter or safety switch, changed fuse, seat switch check seemed to be ok - any suggestions?
Those tractors have a few safety switches and they all have to be engaged in a closed position for you to have ignition and have unit operate. Did you check the obvious ? - ignition switch?
If it just stopped dead while you were mowing then the ignition had to have been interrupted. That switch powers both the starter and ignition circuits.
Sep 11, 2016 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Why does snapper rideing lawn mower stall when brake is relased?
Hi Jerry:
These machines have a lot of safety switches intended to protect the operator.
If no-one is sitting on the seat (activating that switch), releasing the brake will shut the engine off.
That's the first thing I'd be checking.
Hope this helps.
Cheers.
Nov 01, 2015 | Snapper Garden
It's a snapper lawnmower and I was wanting to know if I could eliminate all those safety switches or not
There is some danger doing so: If you have a safety circuit schematic you could by-pass switches for dummies.
Jul 26, 2015 | Snapper Garden
SR1642 Snapper rear engine, what is the fuse for?
Most the fuse is for starting. The park brake probably has a safety switch. It needed adjusted.
Jun 24, 2014 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Snapper sr1030 mower
This question is to vague,to answer! Sorry,Sincerely,Brad Locke DTD 12/04/15
Aug 18, 2012 | Sears Garden
I have a snapper 28 hi vac riding mower that won't
first try and start it with carb cleaner or starting fluid with the air filter out if it fires then its a carb/fuel problem if not it could be a spark problem remove the plug connect hte wire back up and crank the engine over while looking for spark if no spark disconnect the kill switch wires from the side of the engine should be a single wire near the throttle cable if spark with that off the problem is in the wiring or safety switch if still no spark its the coil
Apr 23, 2012 | Briggs & Stratton Garden
Need wiring diagram for snapper mower model 260612t without electric star
don't have a diagram but i find the safety switch relay goes bad just disconnect it go right from the key switch to the engine just to test it of course also check the switch on the shifter handle
Apr 22, 2012 | Snapper Garden
I have a snapper sr1030 but it is not firing i have replaced spark plug
It will take 3 things to make it run. Fuel, fire and compression. Try this. Squirt a little starting fluid in to the carburator and try to start it. If it fires you then need to check to see if there is gas getting into the carb. If it doesnt fire, you are not getting any spark due to a shorted coil, bad coil or shorted wire. If it has been outside for a while where it is damp, your magneto and coils may have enough rust on them to prevent them from firing.
Mar 11, 2012 | Garden
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
