Question about Tacsew Sewing Machines
My t20u73-1 is sewing zig zag instead of straight stitch while on straight sewing setting?
bargainbox
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
bilabon
  • 46 Answers
SOURCE: zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Posted on Sep 02, 2008
RickE1
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
My new Singer 4411 will not do zig zag or other stitches, just plain sewing
josephamoi Nov 17, 2017
When sewing ziz zag stitches the zig zag dial on your top right hand must be set any thing thing above 0. The setting is 0 to 6. Only on straight stitch this dial be set at zero.
Nov 15, 2017 | Singer Sewing Machines
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
HOW DO YOU CHANGE THE STITCHING FROM STRAIGHT TO ZIGZAG
Check that your sewing machine is even capable of zig-zag. Some machines are straight-stitch only.
Consult your owner's manual.
If your machine can do zig-zag, somewhere there is a dial or setting called "stitch width" that will determine how wide the zig-zag will be.
May 21, 2016 | Sewing Machines
Why won't my zig-zag zig zag?
Check your stitch width setting if its too low it will just straight stitch.
Jan 21, 2015 | Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Jul 26, 2009 | Necchi Sewing Machines
Sewing Machines Logo
21 people viewed this question
Top Tacsew Sewing Machines Experts
Rommel Balcita
Nick Olsen
Ruth summersides
Are you a Tacsew Sewing Machine Expert? Answer questions, earn points and help others
