Question about Royal Sc120 Shredder
How to empty Royal Shredder sc120 - Royal Sc120 Shredder
  • 45 Answers
SOURCE: Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
Posted on Apr 16, 2009
  • 1218 Answers
SOURCE: how to empty full royal vf1000mx shredder. No,
You may have the basket completely full and jammed with paper which is why it won't come out easily.....you will just have to try to slightly lift the basket and pull forwards to remove it.
Posted on Jun 30, 2010
  • 1218 Answers
SOURCE: how do you empty royal 10x shredder?
Remove the waste bin from the front and empty.
If you have it jammed so full the bin wont come out I have heard people say that they got the bin out when they turned the machine upside-down....be aware this might make a mess.
Posted on Oct 07, 2010
  • 1218 Answers
SOURCE: I am unable to open the shredder up in iorder to
If you have "overfilled" it, then yes it can be hard to get the bin out...there is no other way than to try to get the paper out a little at a time until the whole bin can be removed.(I heard of one customer say they got it out by turning the machine upside-down) altho' I have never tried that myself. Be aware this may make a mess while trying to get the paper out.
Posted on Jan 09, 2011
  • 1218 Answers
SOURCE: Royal Paper Shredder model SC120. I need a
Give Royal a call at 1-800-524-0799 for parts assistance.
Posted on Feb 09, 2011
Where can i buy a replacement basket for my Royal SC120 12 sheet crosscut shredder
you may get one from the manufacturer spares on line
other wise take the top opening measurements of the container and you may get one from you local hardware shop in the plastic container section that will do as a replacement
Sep 01, 2015 | Royal 12 Sheet Cross Cut Shredder SC120
Royal sc120 shredder wont run.. Paper jammed in head and cannot remove it--no reverse or forward will work.
This is the most common problem..."too much paper".
If it won't go in either direction the only option is to open the cutting head of the machine(after unplugging) and to manually try to turn the gears to un-clog the paper.
Once you have cleared the paper from the cutting blades see if it still turns...see if any plastic gears have been damaged. Plug it back in and see if it runs...if it dosn't you may have blown the PCB in which case you should contact Royal at 1-800-524-0799 regarding replacement parts.
Jun 14, 2011 | Office Equipment & Supplies
My royal sc120 shredder will light up but there is no sound will not run. I have cleaned out clogged bits of paper. What could be wrong?
Shredders have a reputation for being very unreliable...they often just quit like that...
You can try also to blow it out with a can of compressed air, but it probably won't help... not much else that you can do...
heatman101
May 27, 2011 | Royal Sc120 Shredder
My shredder won't start. I emptied it and then when I put it back together it didn't work. Any ideas?
Sounds most likely that you dont have the waste bin back in properly...do a double check there.
Feb 15, 2011 | Royal Sc120 Shredder
How do you empty royal 10x shredder? PX1000MS Platinum
Jul 22, 2010 | Royal 10X Shredder
I have the Royal SC120 model. The shredder does
1 or 2 gears are broken. royal doesn't make many replacement parts for their machines, might try calling royal at 1-800-222-2310. I would recommend replacing unit with a Fellows brand shredder. royal also makes Ativa brand- don't buy it either.
Dec 11, 2009 | Televison & Video
Royal Sc120 Shredder Logo
127 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
