Question about Body by Jake Ab Scissor Exercise Equipment
How to assemble body by jake bench - Body by Jake Ab Scissor Exercise Equipment
I need a manual for body champ 605b weight bench
Try Googling (body champ)(605b)(manual) without parens.
Jul 02, 2017 | Bench Exercise & Fitness
Who are Finn and Jake?
Finn is a human boy who was found by Jake's dad, Joshua, in the forest. His duty is to protect the Land of Ooo from evil such as the Lich. Jake is a magical dog who can stretch to any length, shape, or size. He got his stretching power by rolling in a magic puddle as a puppy. Jake's blood relatives consist of Joshua, his dad, Margaret, his mom, and Jermaine, his brother. All of his blood relatives are dogs as well, but none of them have stretching powers like Jake. Finn is also Jake's adopted brother. Jake's quest is the same as Finn's, being righteous and such, but Jake is more laid back and like's to goof around and mess with Finn.
Sep 04, 2016 | Adventure Time with Finn & Jake (2010)
Remove starter solinoid from starter when still in car
it will not be possible to remove te starter solenoid as it is held in by a pin and a pivot section in e body of the starter
remove the starter assembly and fix it on the bench
Oct 24, 2015 | Cars & Trucks
Body by jake ab scissor is broken
I just fixed one for a friend of mine. The rectangle tube goes inside the square tube for handles and is welded. The problem I think is the heat from welding changedo the hardness of the metal and it breaks instead of bending. I fixed it buy welding two 1/2" X 4" solid still bars inside the broken tube. Thereason is no way that joint will break now. Somewhere else, maybe, but not there.
Mar 27, 2013 | Body by Jake Ab Scissor Exercise Equipment
Jan is twice as old as jake. The sum of their ages is 5 times jake's age less 48. How old are Jan and Jake
Jan is 48 years old and Jake is 24 years old.
(Jan - N, Jake - K N=2K N+K=5K-48 N+K+48=5K N+48=4K N+48=2N 48=N K=N/2=48/2=24)
Thanks, that was fun.
Jul 26, 2011 | Washing Machines
My grinder starts slowly and takes time to build up to speed. It is a model 612 and does not appear to be a capacitive start motor. All I can see under the base plate is a relay. Thanks for your...
Hi and welcome to FixYa, I am Kelly
Inside your grinder either the stationary switch or the rotating assembly that actuates the stationary switch has failed.
Download this pdf file:
http://www.baldor.com/pdf/literature/CA506_0806_WEB.pdf Then go to page 9
The rotating assembly is this part number: (most common failure)
34RS2060SP
You must remove the end plate / cap to change this part.
The statonary switch rarely fails unless the rotating assembly damaged the contacts when the rotating assemble failed. When the rotating assembly fails you often find a spring and flyweight loose inside the grinder during disassembly. Should your stationary switch have failed try and get a number off of it so you can get the right switch. Otherwise you have to use NEMA code / Body type numbers.
Thanks for choosing FixYa,
Kelly
May 06, 2011 | Baldor 612 6" Bench Grinder 3600 Rpm Stamp...
Diagram showing assembly of 4 parts of cutting head
I solved the problem finally. I discovered that the plate which has the 2 large threaded holes which carry the fixed cutter, had to be locked in behind 2 spring fixing points (on the body of the clippers) before inserting the tongue into the body of the shaver. When I first removed the plate I used a screwdriver blade to spring the tongue away from the body and the whole caboodle (4 pieces) fell out on the bench, so I didn't see how it was assembled. Thanks for your interest anyway.
Jan 08, 2010 | Kitchen Appliances - Others
Have lost instruction manual - Total Body Trainer
ask at manualfox.com
they will get it.
Mar 11, 2009 | Exercise & Fitness
Body by Jake Ab Scissor Exercise Equipment Logo
99 people viewed this question
Top Body by Jake Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Body by Jake Exercise and Fitnes Expert? Answer questions, earn points and help others
