Question about Photography
How to take clear pictures with pentax kr - Photography
  •  Mike
    Mike Feb 13, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Will lens from a sf1 fit the newer models like the Kr or better
Yes. The new digital model cameras will accept the older K-AF lenses.
Mar 01, 2013 | Pentax Sf1 35mm Slr Film Camera 35-70mm...
What kind of lenses should I buy for my new Pentax Kr? People tell me to buy new digital lenses. What is the real scoop on lenses for this camera?
Newer lenses tend to be sharper and lighter than older lenses, and with better optical characteristics. Some digital-only lenses are also designed for the smaller sensors of some digital cameras, allowing for further reductions in size and weight. In general, lenses designed for film cameras will work with digital cameras.
If you already have Pentax-mount lenses, by all means continuing using them if you're satisfied with the results.
Jul 20, 2012 | Ricoh Cameras
Shutter clicks ever time I press a button & it won't take pictures
I had this problem this afternoon, and it resolved itself when I took the memory card out. It's been fine so far, all working as normal again! :)
Apr 16, 2012 | Pentax Kr Digital Camera
I have a Pentax K10D from the time they were first sold. I have not installed any firmware as not very technically talented. Have recently bought a Sigma 120-400 zoom.( no zooms of this range from...
Only Pentax DA and FA J lenses and D FA/FA/F/A lenses having an "A" position on the aperture ring can be used with this camera.
The lens you have is HSM DG
Jun 10, 2017 | Pentax Cameras
I have a Pentax K100D and occasionaly when I push to button to take a picture it does not work. I have to turn off the camera and then try it again. It is in Auto mode. Is this a "fixable issue"...
When this happens, does the battery indicator show no battery power? If so, this is a common issue and most owners check the battery indicator first before snapping and if it shows empty, they do the "turn off/on" routine. The newer cameras (K7, Kx, Kr,K5) do not seem to have this problem.
Nov 11, 2010 | Pentax Cameras
Pentax Espio 115 exhibits an H3 error and camera does not work. Sometimes it's a H2 or 1 error. What does this mean.
RE: Pantax ESPIO 115
Dear Sirs,
I bought the Pentax espio 115 Camera in Tokyo and have been well using but it was out of order suddnly .I could find in Lcd panel appeared <H3 mark>and not worked after.
Kindly let us know as quickly as possible what should I do shoot the trouble..??!
Awaiting your kind response.....
Thank you.
Mr.U.S,Yu?South Korea
email:elvisu@lycos.co.kr
Mar 21, 2008 | Cameras
CRT KR & KG Sort
If these guns have cathode-filaiment shorts you might be able to get an isolation transformer made especially for this problem. Otherwise you need to replace the picture tube. Stargazer
Aug 11, 2007 | Sony KV-35S42 35" TV
Photography Logo
43 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
