Question about Kitchen Ranges
How to remove blade from qualcast concorde 32 lawn mower
  • 1114 Answers
SOURCE: Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Posted on Aug 02, 2009
  • 16 Answers
SOURCE: Please advise on where to puchase replacement
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Posted on Aug 31, 2009
  • 1584 Answers
SOURCE: How do I change the lawn mower blades?
If they are riveted then replace the disc....if bolted simply unbolt.
Posted on Jan 14, 2010
heres2maine
  • 84 Answers
SOURCE: how do you change a blade on a qualcast lawn mower
Block the blade with a piece of wood so it stops the motor and blade from turning while your loosening the nut.
Posted on Jul 10, 2010
  • 277 Answers
SOURCE: toro lawn mower model 11-
sounds like the belt broke or jumped off the rear pulley.
don't forget to vote for me.
thanks
Posted on Jul 07, 2011
How do I fix the drive for blade on qualcast 4000 electriclawnmower
When you start mower does the motor run. If so you may have broken the safety pin in the blade adapter drive that the blade is bolted on. if so you have to take the blade off and the blade adapter. that the blade is bolted on and there should be a groove on the drive shaft that the adapter slides on. The safety pin goes in the blade adapter.
Apr 24, 2016 | Garden
How do you remove a bosch-Qualcast 32 easi task blade ?
there is a small hole above the blade, stick a screwdriver into the hole, this will block the motor from turning, then the nut the hole may be hiden by grass,
Aug 13, 2014 | Garden
How do you higher or lower the blades of qualcast hover mower
There are not any levers or anything to adjust blade height.
You change blade height by placing spacers above and/or below the blade. You have to remove the blade and relocate the spacers on the blade bolt to move the blade up or down.
Jul 01, 2014 | Garden
Qualcast rm34 assembly
I'm not familiar with the Qualcast rm34 assembly, BUT... from the "smoke" from beneath, I suspect that something has jammed/locked the blades, or blade pulleys, and the resulting slippage of the belt is causing the smoke.
With engine off, AND the spark plug wire FAR REMOVED from the spark plug, CLEAN OUT ALL DEBRIS FROM beneath the deck, above deck, AND from all areas in contact with the belt!
May 04, 2014 | Garden
How do I Raise the blades on a Qualcast Concorde
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 16, 2012 | Cars & Trucks
How do I replace the on/off switch on my qualcast concorde 30 lawn mower?
Does the new switch have wires connected to it that are same color and switch is identical?
Jun 14, 2012 | Garden
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Aug 30, 2009 | Garden
Kitchen Ranges Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
