Question about Cuisinart Coffee on Demand 12-Cup Coffeemaker
Cuisinart on-demand coffee maker
The gauge always reads full even though the coffee maker is empty.
5 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart coffee maker won't brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
  • 85 Answers
SOURCE: cuisinart Coffee on Demand?12-Cup Programmable Coffee
Hello crystalmeikl,
This is a really common problem with the cuisinarts. I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, crystalm. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
  • 85 Answers
SOURCE: The red cleaning light on my cuisinart coffee
Hello sandra_strat,
There are two possible issues, but easy to do. When decalcifying your unit the solution should be 2 parts water and 1 part vinegar. So if you have a 12 cup maker it would be 8 cups water and 4 cups vinegar. Complete the process with a pot or two of fresh water to rinse. Second, there may be a water filter stick that is removable. Open the lid and look for it in one of the corners, pull it out and remove the carbon filter there. (You can get a new on Amazon). Then replace the stick.
I hope this is a help for you. If it is please leave positive feedback for me. Thanks! NormanZ
Posted on Jul 14, 2009
freetek
  • 5568 Answers
SOURCE: Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
Posted on Jul 15, 2009
Why do I get so many coffee grounds in my cuisinart on demand coffee maker?
Many times this is a result of the coffee grind. To overcome this with some brands, I use an additional filter, put the desired amount of coffee in it, and then fold the sides over to make an envelope. Place the folded sides down and brew coffee. If any of the coffee gets out, the second filter should catch it.
Mar 25, 2015 | Cuisinart DCC Coffee Makers & Espresso...
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
I have Cuisinart Coffee on Demand 12 cup coffee maker. It won't brew a full pot of coffee anymore. It stops at somewhere between one quarter and one half and then beeps that it is done brewing.
Hello, oneill
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about CoffeeMakers and possibly yours, from
repair to trouble shooting it. b>http://home.howstuffworks.com/coffee-maker4.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Sep 07, 2011 | Cuisinart Coffee on Demand 12-Cup...
I have a Cuisinart Coffee on Demand maker and it will no longer brew. Its less than a year. How can it be fixed?
mcdevito75 here, May need to be cleaned a swater will leave deposits, refer to owner manual for cleaning.
Jun 22, 2010 | Cuisinart Coffee on Demand 12-Cup...
Water stays in the coffee basket...
I just had same problem. Please see the solution I provided for Donna_Young. Should be a help. Regards, norm49629
Jul 04, 2009 | Cuisinart DCC-1200 Coffee Maker
THE SELF CLEAN LIGHT COMES ON AFTER BREWING, EVEN THOUGH I have clean it several times
Unplug the unit for one full hour, and when you plug it back in, the self-clean light should have disappapeared.
Mar 10, 2009 | Cuisinart DGB-600 Coffee Maker
Cuisinart Coffe Maker has no power
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
115 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
