Question about Vent A Hood BH234SLDSS Decorative Wall Hood Liner with Dual Level Halogen Lighting and Magic Lung Filter-less Blower: 36" Stainless Steel/600 CFM Blower
How do i change the lightbulbs on my ventahood bh234sldss ?
Tip
I can not believe I have to jump through these hoops just to change a feaken...
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at cdpays@bellsouth.net.
Craig Pays
Kenner, La.
on Aug 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How do I change the lightbulb?
If there is an internal lamp, disassembly will be required for replacement.
Nov 28, 2014 | Steinel IS140W - NightGUARDIAN Motion...
How to change shifter lightbulb
Pry out bezel around shifter very carefully, remove clip/screw for shifter handle after pushing down small chrome cover on bottom of handle. Remove shifter cover (screws or clips hold it in place) to gain access to blub. 1/8 turn to left on socket and it is out
Sep 01, 2014 | 2006 Nissan Sentra
Ventahood b200msc
That would depend on what country you are in. If it is not the USA then it is most likely the voltage is 220. The products are listed here: http://ventahood.com/specifications.jsp IT appears that you dont have the right model number.
Apr 07, 2014 | Kitchen Ranges
Dash ligthbulb change
you will have to remove the instrument cluster
Nov 17, 2009 | 1998 Ford Thunderbird
4359741 You have to remove the outer case and it will be accessible. Eric
Aug 02, 2009 | Whirlpool GT4185SK Microwave Oven
The stop ligths is off
try changing the lightbulb by removing some screws on the back you can take the plastic covering off and then you would be able to remove and change the lightbulb
Jul 01, 2009 | 1996 Chevrolet Beretta
Change the lightbulb in a d3530
Called the manufacturer direct and saved $$$ by not using your site!
Jan 24, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Changed lightbulb
simply changing the lightbulb should not cause a problem like that. It sounds like you accidently shorted out two terminals during the process, which probably blew out the power board on the unit. I wouldn't trust it any further unless you were to take the entire unit apart and find the "blown up" component and replace the board that it's on. Believe it or not, it's not that hard a job if you're up to it.
Apr 22, 2008 | Goldstar MV-1526 Microwave Oven
Vent A Hood BH234SLDSS Decorative Wall Hood Liner with Dual Level Halogen Lighting and Magic Lung Filter-less Blower: 36" Stainless Steel/600 CFM Blower Logo
78 people viewed this question
Top Vent A Hood Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Vent A Hood Kitchen Range Expert? Answer questions, earn points and help others
