Question about Gendex AcuCam Concept IV Orthoralix 9000 Digital Dental X-Ray
Blue coolant light as come on. Keeps asking me to reset but....it goes around as if taking OPG. Then asks to reset again. Please help
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 09, 2013 | Horizon T203 Treadmill
Our temperature gauge goes from a blue light to a flashing red. after putting more coolant in, it seems to correct the issue for a little bit then it happens again. Why is this light going on?
The blue light is only supposed to indicate low engine temperature, reminding you to go easy on the engine until the light goes out.
The flashing is either for low coolant or for overheating, and it sounds like you are having a low coolant problem.
If after you add coolant the lights comes back, you have a coolant leak. The most common place for a leak is the coolant flange on the end of the cylinder head. If you take the engine cover off and look at the area where the transmission meets the engine, you should see either pink coolant puddling or pink crusty residue.
It's also possible to have other leaks from the radiator, heater core, water pump, etc. The nice thing is that with the pink coolant it will leave a trace of pink residue leading to the leak if you take a good look around with a flashlight.
Feb 17, 2011 | 1999 Volkswagen Beetle
1997 jeep TJ, thermostat
about 10-20bucks ez fix buy a new thermastat replace it, if that doesnt work ,then get a coolant flush....if you need help locating the thermastat.. go to ask.com and ask where is the thermastat on """"""""""""///(your veh)
May 18, 2009 | 1997 Jeep Tj
WONT HOLD DATE/TIME, KEEPS REQUESTING TO RESET!
Hi there, been playing around trying to get camera going,as i took apart (easy enough, if you can handle a watch repair screwdriver) what i did find seems to be a standard watch battery located bottom left next to speaker. Pretty sure if you replace this, it should solve your problem. Just be carefull when taking out ribbon cable!
Cheers Greg.
Apr 24, 2009 | Sony Cybershot DSC-T200 Digital Camera
Tom Tom one reset itself and now stuck on language
firstly don't use tina when you're done with the setup change the voice to Tina again
or download TomTom Home
Apr 20, 2009 | Tomtom ONE XL GPS
My Ipod classic 80 gb is frozen and won't turn on or charge!! HELP!!!!!!!
If it keeps happening (and your hear clicking or repetitive sound from inside) you have a broken hard drive. Open the iPod classic and replace the hard drive. The part is available on ebay. Here's a guide on how to disassemble an iPod classic. Maybe a tech savy friend can do it for you. If you want to pay to have a service do it for you there are third party iPod Repair Services.
Mar 19, 2008 | Audio Players & Recorders
Blue bulb emits light, but no picture.
Phillips have been known for the coolant to get contaminated especially in the blue CRT. it congeals and your picture will become hazy and out of focus.This is something you an do yourself. If youre careful. If you would like instructions on how to do this proceedure. Let me know.
Jan 21, 2008 | Philips 55PW9363 55" Rear Projection...
Panasonic pv-gs12 reset
Take the battery and/or any power sources. When it is turned off with no power, press the reset button momenterily. I hope this helps.
Sep 24, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
CA200 red light stays on, wont turn on
The machine is now part of a land fill elsewhere. Do to the company's attitude and refusal to help figure out what was wrong, they will not get another dime of my money. It seems that - when I tested - several of the components were zapped. I found at least one z diode out on the power supply end. I was not about to start fooling with the flyback xmfr. What amounted to the chrona wires tested fine. It is a neat idea but the company is worthless as far as customer relations. The "service" person could barely speak English (Engrish). They did not know a transistor from a fuse! I will recommend this product TO NO ONE. Ionic Pro - are you listening??? A VERY DISSATISFIED CUSTOMER!!!
Jul 07, 2007 | Ionic Pro CA200 Air Purifier
Gendex AcuCam Concept IV Orthoralix 9000 Digital Dental X-Ray Logo
285 people viewed this question
Top Gendex AcuCam Concept IV Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a Gendex AcuCam Concept IV Medical Expert? Answer questions, earn points and help others
