Question about Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994
Location off relay for ford fushion hatch back
What would it cost me to change the transmission fluid myself in my 2011 Ford Fushion
Fluild / Oil in UK £5.00 liter needs 2 / 3 liters Dollars $ 8.00+_
Mar 16, 2015 | 2011 Ford Fusion
2001 volvo v70 tailgate lock/unlock relay location. Tailgate not locking checked fuses, no sound from tailgate, however do get click sound from fuse area.
Check the wiring to the rear hatch. The cables break and cause a variety fo problems like yours. You will have to take the plastic cover off and expose the cables.
Mar 01, 2015 | 2001 Volvo V70
HOW MUCH WILL THE DEALERSHIP CHARGE TO REPLACE THE BLOWER IN A 2009 FORD FUSHION
They usually charge between $60 and $90 an hour. Of course, this can vary by location. You will have to call the dealership and get an estimate before you take the car to them. They can often give you a rough idea how much such a repair would cost over the phone.
Aug 25, 2014 | 2009 Ford Fusion SE
Lg840g will not pair with ford sync system
The phone will not connect with my 2010 Ford Fushion but I just rented a 2013 ford C-max and the phone worked great. It appears a code update is probably the solution.
Nov 26, 2012 | Cell Phones
I have a 2005 Honda Odyssey that is having problems with the power locks. The remote can unlock the doors but not lock them, they have to be locked manually. The back hatch does not lock either. Is...
Do the door lock switches on the doors work both ways? If not, then check to see if you have different relays for the lock and unlock functions, like my jeep does. You may have a burnt relay or possibly a bad / stuck switch. My relays are not in the fuseblock, but in a separate relay center under the glovebox, so you should check your owners manual for the relay location. The only way to lock the back hatch would be by key, but you'll have to relock it everytime you use the remote until you can find the problem. You should also check out your ground wire for the lock circuit. Happy hunting!!
Nov 05, 2010 | 2005 Honda Odyssey
Rear hatch door sensor location on 1998 windstar
most rear hatch switches are on the latch itself, inside the door
Mar 25, 2010 | 1998 Ford Windstar
No power to fuel pump
I NEED TO FIND THE LOCATION OF A FUEL PUMP RELAY ON A 1990 FORD MUSTANG
Aug 11, 2008 | 1988 Ford Crown Victoria
Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994 Logo
71 people viewed this question
Top Mopar Performance Clothing Accessories Experts
Da Doc
ray gallant
Are you a Mopar Performance Clothing Accessory Expert? Answer questions, earn points and help others
