Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
What is the split key on my samsung remote - Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
Auto delay on splits
All Split ac units have a safety system in them for a smooth switch over.
The delay time is different in all units especialy if they are "Inverters" or "soft start"
To be extra safe , just select prefered Temp and then Put it all on Auto.
Also some models have an anti tamper lock on the remote settings.
Feb 02, 2010 | Heating & Cooling
Need to change the hand-set remote battery
To replace the battery:
1. Press the button to flip out the key.
2. Turn the key fob so the metal key stick out to the right and the channel that the key fits into is facing you. (The VW logo on the fob will be facing up)
3. Look closely inside the channel. It is split vertically. On the left hand side of the vertical split, it is also split horizontally.
4. Insert a flat blade screwdriver into the horizontal split and twist. They key fob will come apart, revealing the battery.
5. The replacement battery is a 3 volt CR2032 'button cell' and is commonly available.
6. Replace the battery with the + side facing down.
Oct 26, 2009 | 2000 Volkswagen Beetle
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
