Question about Dishwashers
What is fault A5 on hotpoint dishwashers? - Dishwashers
Hi we have a Hotpoint Aquarius FDAL28 dishwasher. Machine turns on, drains and fills but then 3 lights keep flashing and washer stops programme. Any ideas what problem could be?
Depending on which lights are flashing, there is either a problem with the electronic control module, or the pump is stuck or has a motor failure. You can see which by comparing which lights are flashing with the pattern on this page of error codes:
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3293-hotpoint-fdl-series-dishwasher-fault-codes
Jul 15, 2017 | Hotpoint Washing Machines
I have an hotpoint sdw60 dish washer that is flashing 2 yellow lights, these are numbers 5 and 7 (fast and dry 40c) and (delicate 50c) can anybody tell me what this means.thankyou
Hotpoint Indesit dishwasher flashing lights fault error codes ...
? 15:08
www.youtube.com/watch?v=FRLbrBPHcnE
May 3, 2015 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/hotpoint-aquarius-fdm-dishwasher-flashing-lights-and-there-fault-codes ...
Oct 02, 2015 | Hotpoint Dishwashers
Hotpoint dishwasher fault code al01
A01 fault code is for the Float Switch. This link explains how to check if it might just be blocked. Checking Dishwasher Float Assembly Dishwasher Repair
Oct 20, 2014 | Hotpoint Dishwashers
Hotpoint Aquarius error code a5 Problem
A05 - Pressure switch has not been reset
Check in the user guide the reset procedure (generally, just need disconnected of power few minutes).
Hope helps.
Jun 16, 2011 | Dishwashers
What is code a5 on dishwasher fdf780
its a pressure switch fault...........
cheers
Mar 27, 2011 | Hotpoint Dishwashers
Hotpoint FDW80 dishwasher showinmg an AL10 fault.
Thank you for your quick reply.
Our solution - Added salt and rinse agent (I think it was probably the salt). All seems OK. No fault warnings showing.
Nov 06, 2008 | Hotpoint Dishwashers
Hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Sep 01, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
Hotpoint fdw80 dishwasher
Faulty heating element. Had the same error and got Hotpoint to replace the element. Error was also confirmed by their engineer.
Apr 13, 2008 | Hotpoint 24 in. DWF32P Free-standing...
HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Mar 18, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
Owen Barnes
