Question about Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system
How to fix up d5/5 and remove disc
I have the display flashing d5/5 and I can't eject the disc inside the player
    Welcome Back:
    Visited the website for 2 consecutive days.
I am not sure about the d5/5 error but you should be able to eject the disc by performing the following, which I took from my user manual.
Turn off the unit. Press and hold the [ >>/>>' ] and [ OPEN/CLOSE ] on the main unit at the same time for about 5 seconds.
Hope that helps.
Paul
Posted on Aug 13, 2014
Honda 12 odyssey cd player says bad disc eject
The symptoms suggest a CD is jammed inside. You will have to remove the player and open it up to find the problem and correct it.
Aug 14, 2016 | Audio Players & Recorders
Why won't the Blu-ray player power up, with either remote or direct input?
Your eject drive is locked up and Your disc will have to be removed manually. It's Blu-Ray Up-Grade time. Good Luck.
Sep 28, 2014 | Televison & Video
I have a cd stuck in the radio & it won't eject it (states no cd), makes a clcking sound. how to fix it?
Usually there is a hole in close to the cd slot, where a pin can be inserted in order to push out a cd manually or a similar manual override.
Which CD player/ radio are you using?
Jul 01, 2017 | 2004 Chevrolet Avalanche
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Hi,I have just bought a Denon dn m991r second hand and I am having problems recording on analog.I press record and DIGITAL IN starts flashing on display,I press play/pause button but nothing happens no...
Go here - http://www.minidisc.org/part_Denon_DN-M991R.html . Get the owner's manual. Read it.
The preset mode changes whether you record analog or digital.
Assuming nothing is jamming or is bent, the weak eject is probably why the guy sold it to you. It can't hurt to take the cover off and watch what happens.
Aug 05, 2012 | Denon DN-M991R Mini Disc Player
Disc won't eject
Dirty or damaged disk. remove screws in back of player (carefully) and gently slide disc out, do not force. Or take player back to store and ask them to fix or replace it.
Joe Don
May 25, 2012 | Toshiba XDE500 Player
Cannot eject a dvd from a dvd player
usually if you look in the front you should find a small hole turn on the Player and push a Paperclip into the hole this is a manual eject for the tray. If there is NO hole then Unplug the Player and remove the outer metal cover Do NOT stick anything into the Inside of the Player taking a flathead screwdriver You can coax the slide tray to eject the disc If it is an internal feed and eject system across the top there should be a crossbar with a spindle in it facing downward onto your disc remover this crossbar and you can safely coax the disc out of the front without damaging your disc. your issue is when the disc was inerted it was misaglinged in the player so the system misinterpreted it as being a No Disc and locked out the ejection of the disc in the players brain there is NO disc in the player at all after you removed your disc reassemble the player and either return it or toss it out for recycling and get another one
May 04, 2012 | JVC Televison & Video
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system Logo
154 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
