Question about Bell and Gossett 185011 Bearing Assembly 1510 Sm Br
P77172 replacment bearings - Bell and Gossett 185011 Bearing Assembly 1510 Sm Br
How long is a giant panda if you know tell me
Adults measure around 4 to 6 ft long, including a tail of about 5 in, and 2 to 3 ft tall at the shoulder.
Males can weigh up to 350 lb.
Females are generally 10-20% smaller than males.
May 28, 2014 | WatchBuddy Giant Panda Bear Head Bear JP...
What is the main focus of polar bears
Polar Bears are Hunters and that is their primary function(food).
Oct 24, 2013 | Watches
Can't tell time or set time on Wylon ball bearing watch. HELP!!! Thanks
fdddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddasdddddddddddddddddddddddddddddddddddddddddd
Apr 24, 2013 | Watches
I will push compass button it will work and display compass bearing but then after about 15 to 20 seconds it will just show hash marks no bearing or degree and it does not show any error message not s
Check out the battery. The clock will work with a low battery, but other things may not. Also, the batteries that are in it may have corroded contacts...clean them off first!
Dec 22, 2012 | Watches
WATCH ON DESKFOR 24 HOURS KEEPS PERFECT TIME'WHEN I WEAR WATCH IT LOSES IN 1 HR. LOSES 40 MIN. BATTERY NEW. OMEGA CONSTELLATION 30 YEARS OLD CAN YOU HELP?
When a watch is on a desk, the balance wheel is vertical, when you are wearing it the balance wheel horizontal.
Has the watch been dropped onto a hard surface?
If the balance wheel bearing is worn or has suffered a large shock, then the shaft may move in its bearings or the bearings damaged, which may give the problem you decscribe.
Take it to a watch repairer to have it adjusted or repaired.
Dec 27, 2010 | Omega Watches
How do you get the bezel off of a tag heuer 4000 automatic, I have 2. The bezel on one is stuck from wearing on very dusty construction jobs, the bezel on the other turns but without clicking. Is there...
Yes, there are special spring under the bezel, not the bearings. Bezels are stuck/not clicking because they are broke/worn out or very dirty. I would not advise to take off bezels, unless you have replacement springs and proper tools to fit the bezels back on watch. You can find bezel springs on Ebay, or visit your closest watch repair shop and ask them to order springs for you. Rate me, plz.
Mar 27, 2010 | Tag Heuer Watches
Ladies Classic Wave Diamond dial
Yes, you can. Contact your nearest Ebel retailer and they will advice you.
Bear in mind- this is a costly upgrade.
Jul 19, 2008 | Ebel Classic Wave 9090F249725 Wrist Watch
Bell and Gossett 185011 Bearing Assembly 1510 Sm Br Logo
Top Bell Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Bell Watch Expert? Answer questions, earn points and help others
