Question about Canon PIXMA MP780 All-In-One InkJet Printer
Can't change image quality on Canon Pixma MP780 when in copy mode
The printer will copy only in 'fine' mode. I have followed all the instructions in the manual but it still refuses to change quality whilst in copy mode. I can easily change the print quality in all other modes. I have no problem using the printer in fax, scan or printer mode.
  • 1 more comment
  • nancyshavick Jun 26, 2009
    In answer to the request for clarification it is when using ordinary A4 copier paper in the main paper tray.
  • Michael Grey
    Michael Grey May 11, 2010
    Remove ink cartridges and print head. Power down then unplug printer for 30 min. Start back up and re-install head and cartridges. This should bring up the align print head option as we are setting it back to factory defaults. If this does not correct the problem call Canon and if they do not fix it over the phone they should not charge the fee.
  • Michael Grey
    What printer tray and what paper?
SOURCE: In copy mode I can't get Image Quality to change from Fine
Ok what I just found out is that if you use the paper key then the menu key to get down to image quality the n the + and - keys to change the selection.
Posted on Jan 11, 2009
SOURCE: canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Posted on Jul 27, 2007
  • 76 Answers
SOURCE: Fax with Pixma MP780
if you can hear it connecting and you can here fax tones then it sounds like it going. just place the page in the adf and dial your number and hit send button. how do youknow that the other person is not reciveing it? if you are in the uk then i can send you a page and see what we get?
Posted on Oct 21, 2008
old marine
  • 2176 Answers
SOURCE: Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Posted on Mar 16, 2009
Maanita
  • 1142 Answers
SOURCE: PIXMA MP780 will not receive fax with Verizon DSL
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
  • Low ring-in voltage can cause short bursts of ring tones at the phone jack.
  • Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
  • Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
  1. Disconnect the fax at the telephone wall jack.
  2. If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
  3. Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
Posted on May 05, 2009
Print quality poor for mp780. Had s800 which
There seems to be a calibration problem. Follow the calibration test from the manual.
If you are using original cartridges, go to canon for repair.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon mp780 is stuck on fine mode and it will not
yes, first change the paper setting button to normal, then you can lower the image quality on copies.
Nov 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My incoming faxes won't print. both black ink cartridges r full
Is there any message when you try to print the faxes?
If there is an "Image Quality" message, probably the printer is set up to "Copy" in "Photo" or "Fine" mode and it needs to be set to something other than "Fine" or "Photo"
Apr 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do I change image quality
I presume you are trying to copy something on your MP780.
In the "Copy" mode, press the "Image" button beside the LCD screen, then use arrow keys to change to another quality, then press"OK" button and the machine should be set to go.
Jan 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Jan 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
MP780 copy mode/resolution
Mine was stuck on fine photo resolution too and it wouldn't print in normal black. I tried lots of things and the only thing that seemed to work was pushing the photo button and then pushing the copy button again. Good luck.
Dec 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma Mp780
A Google search produced the following result (among many):
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=All-in-One+Printers&series=All-in-One+Printers&model=PIXMA+MP780&menu=Manual
Download the manual and follow the instructions.
I am not familiar with Paint, but there may be a way to "Import" images in the (Paint) Help files.
Good luck.
Apr 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
The problem is that only "fine photo pro" is available when the paper selected is photo paper. Change source to the sheet feeder, hit the "Paper" button and then select normal paper. You'll then be able to change the quality to normal.
Sep 22, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Color images printing in stripes
yes clean your ink well manually
here is the service manual for your printer
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
it has trouble shooting and step by step repair instructions
Aug 28, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp780 Copying mode very slow
is this using it on its own[Stand alone mode] or through the computer?
May 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
160 people viewed this question
old marine
old marine
