Question about Gilmour No 2pgt Green Thumb 2 Gal Ld Tank Sprayer
How do I open sprayer? - Gilmour No 2pgt Green Thumb 2 Gal Ld Tank Sprayer
Wiper sprayer is clogged how to get them off
It's easier to disconnect the hose leading to the sprayer, and "blow it out" with a can of compressed air. (Or perhaps, disconnect the hose at the _opposite_ end, so you still have the hose connected to the sprayer; and then it's easier to "blow" through the hose to open the sprayer).
Oct 16, 2015 | 2004 Oldsmobile Alero
How do you refill?
Remove all pressure by keeping the hose open until no pressure is left. place pump handle down toward tank. Turn count counter clock wise to unscrew. Take assembly out of tank then fill tank. Reinstall in reverse order.
https://www.chapinmfg.com/sprayers
May 24, 2014 | Chapin 2 Gallon Spectracide Sprayer
Window sprayer will not spray onto window for 2003 Mecury sablewhat happened
by using a pin to clear the nozzle all you are doing is pushing the obstruction back into the hose which immediately comes back into the nozzle blocking it again. Take off the hose to the nozzle and use compressed air to blow the obstruction out of the system
Jan 10, 2014 | 2003 Mercury Sable
I have a ge quietpower 3 dishwasher. Lately it has stopped cleaning the dishes. Sometimes the dispenser tray doesn't open. Sometimes it does open and the soap pac hasn't disolved.
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Jun 10, 2011 | Maytag Dishwasher
The sprayer makes noise like it wants to spray but does not spray
water is getting to it but not passing through, i have never seen one of these but deal with sprayers all day long sooooo open it up there is a valve somewhere that is stuck clean all components and lubricate with petroleum jelly put back together if it doesnt work u need a new one
Jan 25, 2011 | Cepia One Touch Pistol Motorized Power...
Frigidaire dishwasher doesn't seem to wash top rack. The dishes are oily with stuff dried on them. It worked for several years before this. I took out the sprayer and ran water thru it to make sure it...
Have you taken the tube that goes to the top sprayer off and washed that out as it may be clogged especially where the sprayer goes on it has a small opening.
Oct 27, 2009 | Frigidaire Dishwashers
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kichen Sink Side Sparyer sticks open
The diverter in the main body of the faucet is sticking. I have included a link to all the kitchen faucets. You will have to determine which one you have but they pretty much use the same housings and guts for each of their single handle faucets. You might have to do a little research on your end so you can find info on how to replace the diverter. It's usually not hard to do.
Apr 10, 2009 | American Standard 2083.102 Standard...
Price Pfister kitchen faucet two handle with gooseneck and pull down spray. The pull down sprayer will not stay up in the goosneck.
It may also be a missing weight on the sprayer hose, or that the sprayer hose is obstructed. Open up the cabinet under the sink and look a half-loop of the sprayer hose that should be hanging down from the underside of the faucet. It must be able to descend without obstruction as you return the sprayer to the body of the faucet. If it is resting on a box of dishwashing soap or otherwise obstructed, then it doesn't have it's full weight to counterbalance the weight of the sprayer head. Capice? It needs the weight of the hose to 'weight it down'. Also, there should be a donut-shaped weight around the hose that should be able to freely slide to tha lowest position of the half-loop as the sprayer is extended and returned. Make sure that's working too.
Feb 19, 2009 | Price Pfister Plumbing
Gilmour No 2pgt Green Thumb 2  Gal Ld Tank Sprayer Logo
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
